Compression On 05 800 Ho
TABLEROCK
Just Bought My First Rev 05 800 Ho Renagade X And Was Wondering What The Compression Should Check. I Tested It And Both Sides Check Even At 128 Is That Normal ? Or What Is Normal ! Sled Has 2400 Miles On It Thanks Tablerock :)
Elevation? Test method - throttle wide open or closed? Engine warm or room temp? Pull till the tester stops?
Mine has 160 at 1200ft. Throttle wide open, room temp engine (55-60), pull it six times.
I have a Ski Doo shop manual for that sled at home. PM me tonight and I will tell you what BRP says it should be!
Its Good To Go
Tested It Again Last Night With Wide Open Throtle And Go 135 To 140 On Both Cylinders Thank Tablerock
this a summit or a mxz? summits had higher compression heads.
its still prob within acceptable parameters...under 125-120 its prob time.. or w/ that many miles, next season do rings?
oh just reread, you have a renegade, that'll have the lower comp head if i'm thinking correctly...so those #s are fine imo.
