T TABLEROCK Member Dec 4, 2007 #1 Just Bought My First Rev 05 800 Ho Renagade X And Was Wondering What The Compression Should Check. I Tested It And Both Sides Check Even At 128 Is That Normal ? Or What Is Normal ! Sled Has 2400 Miles On It Thanks Tablerock
Rave Well-known member Lifetime Membership Dec 4, 2007 #3 Elevation? Test method - throttle wide open or closed? Engine warm or room temp? Pull till the tester stops? Mine has 160 at 1200ft. Throttle wide open, room temp engine (55-60), pull it six times.
PJ-Hunter Paid Premium Member Lifetime Membership Dec 4, 2007 #4 I have a Ski Doo shop manual for that sled at home. PM me tonight and I will tell you what BRP says it should be!
G gcmci Well-known member Dec 5, 2007 #6 TABLEROCK said: Tested It At 1000 Ft ,closed Throttle At 65 Degrees Click to expand... Just a waste of time if you don't open the throttle all the way to let some air in.
T TABLEROCK Member Dec 6, 2007 #7 Its Good To Go Tested It Again Last Night With Wide Open Throtle And Go 135 To 140 On Both Cylinders Thank Tablerock
R rotax Well-known member Dec 6, 2007 #8 this a summit or a mxz? summits had higher compression heads. its still prob within acceptable parameters...under 125-120 its prob time.. or w/ that many miles, next season do rings? oh just reread, you have a renegade, that'll have the lower comp head if i'm thinking correctly...so those #s are fine imo.
