Camso DTS Lever
Feb 26, 2008
618
219
Has anyone found a different brake lever that fits the Camso snowbike kits?
Trying to find a shorter or adjustable lever and Hayes no longer supports that master cylinder or will be any help.
Im using one for a RH brake for disabled rider. Hes getting good enough that hes covering the brakes while riding and its uncomfortable for him.
I bent the lever to be closer to the bar but its just an awkward style lever and not like a mx lever.
7,927
6,690
Swap the whole master cylinder.
Ebay special.
Jan 14, 2004
3,079
1,390
I just run the stock Yamaha YZ front brake master and lever. Standard 10mm banjo fitting, it bolts right on. Tossed that stupid Hayes set up on day 1. Just unbolt the old one bolt on the YZ one, add some fluid and bungee cord the lever over night, it'll be bled by morning as any air is right at the top of the cable. Don't try to push the bubbles all the way through the system.
M5
Feb 26, 2008
618
219
This lever has to get around a thumb throttle assy. I was hoping to find a at least an adjustable but Ill probably just get the welder out.
