I hate to admit it but I'm a bit confused about primary clutch spring pressure and the weights.
What is the difference between these two scenarios... given the same design to the weights 9not heelclickers or other wieghts that you can change position on0
All other items are the same.. secondary and gearing.
I am also assuming the the weights are properly matched to the spring force
1) Lighter weights on lower force primary spring.
2) Heavier weight on a higher force primary spring.
What are the differences in how the cluch system performs with the two different weights/sprigs above?
