R
I am having a issue with high egts at a consistent 1/4 to 1/2 throttle. If I hold the throttle constant for a couple hundred feet my egts will instantly spike to 1300. I am sure they will keep rising but never tried it holding it longer. I had the same problem last year and thought this new update would fix the problem, but not the case. I have tried raising my fuel numbers and it dont seem to make a bit of difference. Its a real pain to be constantly blurping the throttle to keep her running cooler. Any ideas?
Also with the new update i am having problems with the check engine light. I assume this is DET? Just got the sled back from updates and even just a quick throttle blurp and it will cut out. This is at 1700 feet with 7 gallons 110 and 3 gallons of 91. Tried running several different sets of fuel numbers, but it seems to be a problem no matter what.
Leaving in two days for cooke and would like to get things figured out. If all goes good i plan on having the polaris dealer in coooke flashing it back to the 09 map for me.
