Bogging on 2020s
ullose272
3,372
963
boise idaho
Anyone having bogging issues on their 2020s? Mine has a pretty bad one in the 4000-5500rpm area. I have 7.5 hours on the sled now, i was hoping it was just a break in deal, but now i wonder if it either my diamond s can, or my bdx intake. Anyone else have this issue?
Sent from my Pixel 3 using Tapatalk
goridedoo
3,868
3,544
I saw a complaint the other day on facebook about an aftermarket intake causing bogs on an Alpha.
Old & slow
728
393
Alberta
Mine is stock with under 2 hours, it has an issue in the same rpm range. I would not call it a bog rather erratic throttle response. It is just not smooth when going slow or slowly adding throttle. Before and after the 4000-5500 it is smooth as it should be. I am going to get through the break in and see if anything changes.
Mar 8, 2019
124
76
so if they are short does that mean The valves don’t fully closes? What’s the remedy do the have an adjustment like a throttle cable?
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
What wires or plug disconnects the Tss? or what do I need to do to by pass it?
Thank you
Unplug this. Its easier to get at if u take the hood off.
Sent it
ullose272
3,372
963
boise idaho
Much much better after adjusting the cables, still a little bog, might try throwing on the stock intake see if that helps
Old & slow
728
393
Alberta
Good to hear, I checked mine and both were to short and not the same. I have not tested since adjustment but expect the same results as you.
