Bogging on 2020s
ullose272
2,886
597
boise idaho
Anyone having bogging issues on their 2020s? Mine has a pretty bad one in the 4000-5500rpm area. I have 7.5 hours on the sled now, i was hoping it was just a break in deal, but now i wonder if it either my diamond s can, or my bdx intake. Anyone else have this issue?
Sent from my Pixel 3 using Tapatalk
goridedoo
2,889
1,764
I saw a complaint the other day on facebook about an aftermarket intake causing bogs on an Alpha.
Old & slow
386
127
Alberta
Mine is stock with under 2 hours, it has an issue in the same rpm range. I would not call it a bog rather erratic throttle response. It is just not smooth when going slow or slowly adding throttle. Before and after the 4000-5500 it is smooth as it should be. I am going to get through the break in and see if anything changes.
ullose272
2,886
597
boise idaho
Much much better after adjusting the cables, still a little bog, might try throwing on the stock intake see if that helps
Old & slow
386
127
Alberta
Good to hear, I checked mine and both were to short and not the same. I have not tested since adjustment but expect the same results as you.
