I've got a 950 Price in a mod MM chassis and recently built a 944 UBR/Fastrax engine for another project. I also run a SLP 800 kit. Sounds like you are clutched about right. What primary spring you runnin? You should be getting much closer to 9000 rpm with what you have there. How long since the clutches were rebushed? Are you using a fresh 8DN belt? I'll see if I can dig up my clutch setup on the 950. I am running P-85/Team setup on mine. If you want another Yami big bore to play with I'd sell ya any one of mine. I have moved back over to the four strokes again and don't need all of the sleds I have now.
My clutches are practically brand new (about 300miles on them) and still clean as a whistle. Still running the 8DN belt and my spring is the Polaris almond. I can pull 9000 on flat ground but couldn't get it to pull the R's on the hills. Might be gearing too need to check that out this summer and make sure it's correct.
19/42 will give you a better gear ratio. I highly doubt you will ever see 90 MPH track speed.
I have one in nw colorado. $1500 for motor carbs and pipes or $2000 for whole sled. 2000 mm with mpi tunnel boss seat and more. old sled, kinda beat up but runs good.where could i buy a ub944? how much would it run me? i want to mod out my MM..
