Best weights for the 800
F
Jan 2, 2013
62
5
39
Hi. My brother has a 17 sks 155 with the 2.4 i believe, looking for best adjustable weights. He likes to climb when he is out west, i suggested mds weights since i run them in a proclimb and like them.
Im not sure which weights Polaris guys tend to like the most.
Thanks for any info.
Jeff
7,913
6,674
The slp magnum force weights are working great for me.
Adjustable from outside the clutch.
Less than a minute on the hill.
Ratchit
ACCOUNT CLOSED
Mar 18, 2013
128
76
here
CPC’s turbo mags or I T’s
Dalton’s
Both are set screw style and easiest to change without taking belt off or moving clutch sheave in . Just my experience
BILTIT
1,682
482
45
Lloydminster, SK
I think the slp magnums are better than daltons, both setscrew adjustable style.
Sent from my SM-G925W8 using Tapatalk
F
Jan 2, 2013
62
5
39
Thanks for the replys, will he need to change springs as well? Or does polaris set them up with good springs and helix from factory?
I had been considering the pro mags, not sure what weight is used outwest mostly?
If we could run the middle range ones that would be great so they could be used at low elevation as well
BD-Xtreme
267
We suggest our 125-310 green primary spring or our 140-310 red if you want the engagement to be above 4000 rpm.
You can use the 52-68 gram versions and run them full at 68 grams at low elevations. Then lighten up to about 60 grams in the mtns depending on the elevation.
indydan
1,245
3,301
Custer, South Dakota
www.indyspecialty.com
Sales of Our Mountain adjustable weights and our Turbo 3 weights have been off the charts last season.
We have 3 new weights for the 850 to capitalize on the low end torque of the new motor.
Patriot Trail
Patriot Mountain
Patriot Turbo
3 completely different weights that will pull harder from top to bottom then any other weight on the market or your money back.
Dan
damx
1,836
1,177
I have Indy specialty weights and mountain 3 helix and never had a sled this good on belts. Very happy.
