finally got my 940 on dyno....dyno at 5k, very experienced shop and operator, does LOTS of dyno work for all brands and hp configurations, up to over 300 hp....my engine, bikeman 940 with his y-pipe and pipe, diamond ti can, stock fuel system with commander v....184 hp at 7900 rpm, interestingly, at same rpm as stock engine, total surprise; stocker was 155 hp, 14 800 m....my '10 put out 163, but of course there was a pipe change...operator said that i would need to run it about 8050 for riding elevations of 9-11k...experience says i should run it at slightly higher rpm so that in changeable snow conditions it pulls down to max hp rpm rather that trying to accelerate back up while under load, a little more testing when we get more snow....to put it in perspective with the bb 800 etec, the best bb, over a dozen tested, pulled 162 hp; stock normally 149-150, not naming which ones, but you would recognize them...this shop specializes in rotax and polaris engines and is very experienced in getting the most out of rotax engines.....most pump gas turbos are in the 175-180 range, with race gas mixes going up to about 205....my '09 m 1000, ported with exhaust got 189. but had 137 ft/lbs of torque, which pulled hills really well...anyway, not trying to upgrade or downgrade anyone else's ride, just an unbiased look at results of different engines that have come thru the shop in the last year.... just to add the info on the '14 cat, light weight, lost 46 lbs; ti can, c-3 belt drive, 16 front end, 3" track, bdx rear suspension, oil delete, bdx hood & intake, cat mesh side panels, led strip light on rear and front, hcr steering post, mohawk skiis, bdx boards, other small stuff, but that's most of it, cost some, yes....beating the poo's, priceless..
