T
My question is how tight to run the chain on an 06 apex with reverse and a rearmount MCX? Does finger tight then back off 1/8 turn sound right?
i run with no slack on the turbo. As tight as i can go with my fingers.
I run with no slack on the turbo. As tight as I can go with my fingers.
well tension may vary from front mount to rear mount application. with a rear mount at 14lbs of boost back off 3/16 but with a front mount maybe a 1/8 to be safe. 18-20 lbs of boost on a rear mount setup you want to be right around 1/8 backed off but with a front mount setup 1/16...any other boost levels above there should be finger tight and add a 1/2 turn because the chain stretches like a mother when boosting at these levels. hope this is helpfulMy question is how tight to run the chain on an 06 apex with reverse and a rearmount MCX? Does finger tight then back off 1/8 turn sound right?
