Flashback:
I had the Firestone RideRites on my old truck and I liked it a lot. Had the dual controller in the dash. It worked well. I like being able to have a shraeder valve at the back of my truck for times I needed air.
My buddy and I just both installed a set of AirLifts on our trucks.
He put the AirLift Load Lifter 5000 on his F350 King Ranch short box.
I put the AirLift Load Lifter Ultimate 5000 on my F50 Long Box.
He may just probably inflate manually and will skip the on-board compressor systems (he's a windbag and can handle that), but I am used to having the in-cab controller on my old truck and I do like it. I put sleds and ATVs on the deck, haul a 5th wheel, pull floats in parades (that can sag a truck FAST!!!)
I like the functionality and versatility of the on-board compressor systems that AirLift offers, but the 7200 system says it's not for use with an air tank. The WirelessOne isn't any better.
Why an air tank?
Welllllll, I also plan to put train horns on my truck (I know the die cast metal are way better than the plastic ones).
According to this page I think I can run them off the same compressor and tank.
SO MY QUESTION.....If I have a separate pressure switch coming off the tank, can I tie those systems together with one compressor and ONE tank so that I can still control my airbags in the range of 10-100psi independently of my air horns that need 150psi?
Why an air tank?
