860 turbo
G
Nov 23, 2012
9
29
13
i need some clutching tips
the sled is overreving in the start and is going in too limp mode some times
my clutch setup is
cpc it 75gram base and 7grams in the heel
slp 170-300 spring
helix 54-46
180-300 team spring
9 psi
Spiderman
220
41
Mn
I just had the same problem with my silber 800 check out my post down the turbo page a little and you will find some useful information that might help. I ended up adding more weight and a steeper helix. You need to list ur elevation and rpms start, spike, and full throttle
sledhed
1,751
435
Lolo, Montana
I was going to say that sounds like a stock 800 helix, my 860 carls which is normally aspirated takes a steeper helix than that. Here are the specs for the non-turbo 860 from Carls:
- Primary
5-8K bright green primary team spring
EPI belly buster 66 gram or Polaris 10-66
- Secondary
66/42 helix
Team black / purple spring
Ended up going to a gold-black Team secondary spring to try to hold RPMs better in spring condition climbing, it helped, but problem not completely solved. Adding a turbo sounds like it would help with my RPMs though!
