A
White smoke sorry...just wreacks of raw diesel fuel. I was checking the pressure iwth a tire pressure guage on the valve on the side of the filter bowl. At this point, I know I need to get or borrow a code reader or something along those lines. I am pretty well convinced that I have an injector that is not shutting off and dumping raw fuel while it sits, and/of on a cold start. The truck has right at 200,000 on it. Ipr/icp/cps are all new in the past couple of years. new lift pump and a few other things. I recently did the injector orings and it needed that badly by looking at the orings. i did have this smoke issue both before and after the oring change so that is not my problem. I was hoping it was the orings, but was not. All 8 were ugly, so that was not a lost effort. Thanks for the help.
Too bad you didn't have the injectors bench tested while you had them out. Still could be that one of the injector sleeves are cracked. One step at a time.
