2022 Expert 34 Inch Front End Thoughts
NHRoadking
1,670
2,053
Thanks for the video. I'd like to try the 34 inch front end, but I'm surprised Doo would narrow the front end and not narrow the sled's side panels too.
I looked at a Polaris and a Doo yesterday, side by side. The Polaris is about 4 inches narrower than the Doo, with each having the 36 inch front ends. I have a hard time picturing the Doo with the 34 inch front end not paneling-out at times/dragging more in the snow when it's on its side
What did you find Dave?
jcjc1
986
937
93
it probably does panel out more but for me that's not a big deal. i priced out the parts and it looks like it's about 500 dollars to convert plus some of that cost could be reduced by selling the old a-arms.
NHRoadking
1,670
2,053
Could you list the part numbers you used for the swap? Thanks.
Norona
2,585
4,681
North Vancouver, BC
www.noronalife.com
Because the skis are narrower, you do not need to tip the machine as much to bite and hold and edge, we did not find it to panel out and if it does plus 50 degrees a rider with that skill level know how to handle it.
NHRoadking
1,670
2,053
Thanks Dave.
jcjc1
986
937
93
using Dave's info that what's needed are just the a-arms (204.99 ea) and tie rods (58.99 ea), I used 2021 parts which won't work since they're not the shorter versions but the prices should be close.
M7sleddn
79
81
18
Twin Falls, Id
I have found that the boards being as wide as they are cause more issues during spring riding, not the panels. Have not had the same issue in the powder. I have had my running boards stop my sled when sidehilling through the trees in spring snow. I switched sleds with my brother in law, 18 Polaris axis, and had no issues taking the same line. I rode a lynx 4100 yesterday and had no issues sidehilling it as its boards are 2" narrower than my ski doos.
M7sleddn
79
81
18
Twin Falls, Id
Seeing how I was able to ride the lynx I measured the width of the running boards on the sleds I have and ride with.
my 17 summit x: 34"
my 18 Free ride: 34"
My 14 Polaris 600: 29"
Brother in law 18 axis: 29"
Lynx 4100: 32"
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
I need clarification, a 36" front end measures at 36" from center of spindle to center of spindle(skis centered) , the 34 in front end measures 35" from center of spindle to center of spindle(skis centered) ?
So it's actually only 1in narrower?
Sent it
Norona
2,585
4,681
North Vancouver, BC
www.noronalife.com
Sent it
Nope currently centered is 37, so set narrow its 36, centered its 37 and set wide its 38, 2022 expert is 34 narrow, 35 centered and 36 set wide
V
Vailguy
368
Foothills
So you dont have to replace the uppers? just lowers? I bet you could cut and retap the existing ends too. Thats what you did with Alt impact kits on the Rev.
idahoskiguy
893
663
93
Boise, ID
Devoted this last winter to learning to ride better in more technical terrain and found my 2020 Expert 165 (set in narrow position) to be very good when the snow was deep, soft and forgiving; in firmer more set up snow paneling out was an issue and made the sled hard to hold a decent side hill compared to my stepson's 2021 Polaris Khaos 155 which did not panel out in the identical conditions.
Ski Doo will hopefully be releasing a new chassis next year that is lighter and narrower.
NHRoadking
1,670
2,053
Devoted this last winter to learning to ride better in more technical terrain and found my 2020 Expert 165 (set in narrow position) to be very good when the snow was deep, soft and forgiving; in firmer more set up snow paneling out was am issue and made the sled hard to hold a decent side hill compared to my stepson's 2021 Polaris Khaos 155 which did not panel out in the identical conditions.
Nope you will need both uppers and lowers and tie rods
For the cost of all that the best bang for the buck for improving handling might be adding Durapro dampeners to the skis and getting rid of T-motion.
Here’s hoping Doo narrows the Summit to fit the new 34 inch front end and updates the 10 year old skid next year.
jcjc1
986
937
93
are you saying Dave is incorrect about just needing uppers and tie rods in your above post or are you referring to something else?
if so that adds another 330 according to the parts fiche that i used for the above calculation. i'm considering doing it to my 2022 Freeride but maybe not if the lowers are also required. we'll see as i'm saving a small fortune in parts/accessories by transferring them to the new sled.
