2017 King Cat vertical steering post
W
wood51282
Has anyone installed a vertical steering post on the new king cat? If so, will the kit for the 1100 fit?
I'm not so sure it needs verticle steering as much as just a taller riser. The factory one is short. And a lower seat. It's like riding with a big fat pillow between your legs.
What Bacon said.....I ended up putting a 6.5" riser in place of the 4.5" riser it came with. I didn't like being hunched over while riding standing up.
Along with that I think the steering support structure is slightly different on the King Cat, so I don't know if the bolt on supports for the vertical post will line up right. I have not checked this however, just some thoughts.
I've done it ready
Order all the parts off 2016 m7000
Works great
Cut hole by were your recoil handle would be for the bottom two bolts
Took bout 2.5 hrs
Hands down better then standard steering
Not even close how better the sled handles
I've done it ready
Works great
Took bout 2.5 hrs
Sounds good mod. Got some pic of the set up?
Finishing this up tonight. It’s definitely possible - I ended up using parts from kit and from the 2016 like was mentioned above. I’ll post more details/pics later. Feels like it puts bars in a great position.
I finished his last week. I ordered the kit from that was offered from 12-15 and the parts from the 16 hcr (poster above stated the year model) - the single post Bay the gas tank is a better fit
From 16 model — the dual post would
Work from either. The kit or parts from a 16 will work. I’m pretty sure you’ll need to stack a few washers if you use the kit to make the single support tall enough.
Disregard the switches - ordered these for my mountain cat and love them - ordered them for the kin cat and ..... they don’t work - ha - should have read the listing a little closer.
Anyone have any pictures or details for doing the vertical steering post on a 2014 m9000?
Still not really sure how this modification works?
So can anyone confirm that using the 2012-2015 vertical steering upgrade kit works? I have spent quite a bit of time looking through parts diagrams and it appears that it should work. I called Country Cat and their tech i spoke with said that it would not work that the steering support system is shaped different. My biggest concern is that the steering shaft works from the kit and that the 3 bolt holes for the supports line up up top.
The Center support is different. You need the one from the M7000 or the Yamaha Viper
When you say center support you mean the back support of the 3 arms on the vertical kit, right? Is the steering shaft the same from the m7000 and m9000?
Thanks for the reply
The M9000 post is different, the spars on the chassis are not the same as the Viper or M7000 (which used a N/A yamaha engine) That said, I never tried mounting an 1100 setup, just bought the tripod from a wrecked viper. If you go this route, pick up a set of Canada Sled Parts bushings, way better then stock.
Ok. I ordered a tripod off of a wrecked m7000 and I just ordered the steering shaft from an m7000. I will look into the bushings you mentioned. Hopefully I have all the right parts now.
Thanks again.
Put my sled back together the other day and i again realized how nice the vertical steering is on the 4 strokes. Brings me back to my old m1100 and i loved that sled. I have a feeling this is going to make me enjoy this sled even more then i already do.
Thanks for the help with all my questions.
