W
Has anyone installed a vertical steering post on the new king cat? If so, will the kit for the 1100 fit?
I've done it ready
Order all the parts off 2016 m7000
Works great
Cut hole by were your recoil handle would be for the bottom two bolts
Took bout 2.5 hrs
Hands down better then standard steering
Not even close how better the sled handles
Anyone have any pictures or details for doing the vertical steering post on a 2014 m9000?I finished his last week. I ordered the kit from that was offered from 12-15 and the parts from the 16 hcr (poster above stated the year model) - the single post Bay the gas tank is a better fit
From 16 model — the dual post would
Work from either. The kit or parts from a 16 will work. I’m pretty sure you’ll need to stack a few washers if you use the kit to make the single support tall enough.
Disregard the switches - ordered these for my mountain cat and love them - ordered them for the kin cat and ..... they don’t work - ha - should have read the listing a little closer.
The Center support is different. You need the one from the M7000 or the Yamaha ViperSo can anyone confirm that using the 2012-2015 vertical steering upgrade kit works? I have spent quite a bit of time looking through parts diagrams and it appears that it should work. I called Country Cat and their tech i spoke with said that it would not work that the steering support system is shaped different. My biggest concern is that the steering shaft works from the kit and that the 3 bolt holes for the supports line up up top.
