Silber
With the 2014/15 riding reason approaching we wanted to inform the snowmobile community of the turbo kits and electronic options we are offering this season for the XM Etec 600 and 800’s. With the release of the new T3 package we but some extra effort into developing some new technology for this application. I will do a simple break down of what we have to offer.
Standard Etec Turbo Kit:
Gt2860 kPa Ball Bearing Turbo
Internal Wastegate Housing
Full silicone intake and air box
Complete Turbo Clutching
AFR and Boost Gauge
Dobeck Fuel Controller
More:
This standard kit is a great entry level turbo kit, don’t let the price fool you, we have been running this kits for years, it creates great power and is very user friendly. The kit is bolt on and is 100% complete ready to go out of the box. The kit comes set at 5psi and can easily be turned up to 12 psi of boost.
External Etec Turbo Kit:
External 40mm Wastegate and Stainless Steel V Band Turbine Housing
AFR and Boost Gauge
More:
The external kit was designed for the more aggressive terrain rider, the use of an external wastegate allows more precise boost control. The boost is more consistent and wont spike during aggressive throttle movement. Utilizing the V Band Turbine housing allows for more HP per psi of boost and faster turbo response due to the better flow and housing characteristics. This kit comes preset at 7 psi of boost and can be lowered and turned up by adjustment the waste gate actuator. Pair this kit with our new secondary ecu and have one of the most advanced Etec turbo kits currently on the market.
Upgrades:
kPa Self Lubricated Turbocharger ( eliminates the oil tank and pump, drops 4lbs off the turbo kit.)
Standalone Fuel Injection Controller: We have a new Secondary ECU this season for the ETEC application. This new box allows precise fuel adjustments from various inputs from the engine including, RPM, Throttle Position, Manifold Pressure, Barometric Pressue, Intake Air Temperature, and O2. We have auto tuning available and only requires a 5 volt input from your Wideband of choice. This ecu comes prewired with all oem connections, so theres no cutting and splicing wires. Comes mapped and ready for your Silber Turbo Kit.
If you currently own a different turbo kit and are looking for a ECU that will allow you to tune your snowmobile please contact us. This ecu will work with any turbo kit available for the Ski Doo Etec.
For more information regarding any of our products feel free to contact us any time.
Justin Silbernagel (320 282 6812)
Justin@silberturbos.com
AFR and Boost Gauge
More:
AFR and Boost Gauge
More:
Upgrades:
