11 and 12 will fit in cases the same BUT 2011 use larger diameter DEKA four hole injectors. You can install 2012-15 injectors in 2011 cylinders, but you must use the 2012-15 orings. There are three distinct orings per injector green, brown,black in that order from tip to rail. The injector will fit slightly deeper in cylinder but I have run that setup on a couple Indy specialties TMX motors for a couple years/ 3-4 thousand miles with no issues.
Thanks Murph, I did read that somewhere and yesterday I finally pulled out the sled parts and took a look. Hole is considerably bigger on the 2011's.
Roni87: Like Murph mentioned I am surprised your engine lasted through that. I had a buddy that did the same last year and destroyed his engine. If those cylinders are around I would check the skirt of cracking. Not criticizing we all do things in a pinch at times, I just wouldn't recommend that to anyone.
I think the big question has been answered about the injector ports. But does anyone know if they lowered the exhaust port in 11 or 12. Again I can't find a 12 here, even though I am pretty sure I have one, to measure against the 11's I have. I though it was the 2012's that lowered. I have personally raised the port back up 1mm on my stock 2015 engine I now keep as a spare. I also experimented with a 1mm spacer (gaskets and spacer equals 1mm) and a shaved head a bit but never took enough time as the season ended. This was something Dynotech was doing on the with one of their customers.
Anyway I have gone on too long. If anyone knows the exhaust port question that would be great, I know I should of written it down when I had the chance, but as usual I didn't . Thanks guys.
