2006 RMK 900 with 2009 Front end kit
aninchlow
It fits and it fits about 95% mod free.
This was force on me by my friend the flatlander running into my sled and blow every peice of plastic on the front end (minus and I mean just minus the hood) to smitherines:mad:. Replacing the plastic or upgrading to this setup with the lift bumper was a no brainer..... or so I thought.... :eek:
There are only two minor mods, relocation of the exhaust hole. Which is very simple seeing as you can use the snow deflector to line up with the rivets and trace the new hole.
Pretty well forget about the SLP airbox. I built a custom one, out of the parts of the slp airbox that weighs next to nothing but the SLP airbox just simply won't fit as the rails that support the bumper and the different front end geometry just make it impossible.
I saw at Backus Racing a 2005 RMK 900 getting the kit and it looked really good. It had a different air box something square and aluminum and it was relatively mod free.
The geometry of the hood vs the sled does not change. I was told by a bunch of people that it would touch the pipe and a bunch of crap, the reality is it didn't move any or change angle at all and the pipe certainly didn't move as it secures off hard points.
Just thought I would post this as every guy in the "know" that I phoned was wrong with the exception of Backus Racing and I'm glad I listened to them. It looks wicked awesome cool.
I wonder if a 2009 SLP airbox would fit in here and tie into the throttle body. Anybody?
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Ya, the new front ends do look good, the only concern I have is that your gonna be pulling in a lot of under-hood heat with the intake up by the pipe like you have it... could lead to a slight power loss over that of colder, denser air. Other than that, looks good:beer;
They didnt make a 09 slp airbox for the 900 because polaris stopped making the 900 after 06. Drawing air from the bottom is not the best idea with the new front end. there is nowhere for fresh cold air to get to the intake.
actually the entire front of the sled is an intake with these large vents. I was hitting 7800 RPM with no problems today climbing.
I was surprised. One thing I did find out was that the front end goes through the snow a lot better now. It was 3' pow today so it was the day to test.
yep, I was wondering in my post what the 800 intake looked like. it might be easy to mod to a 800 intake easier then building another complete system.
intake
Sorry to brake the news to you but this is not going to work on big powder days. I'm running the 09 front end on my05 900 and the front of the nose fills up with snow right wear your pulling air from. THE FIX IS THIS you need to get a new stock boost box from polaris & put a Fire-Ice intake on or a Timbersled intake i run the timbersled put have alot of vents to get cold air in, The Fire-Ice will work better, if your not going to do all the venting this sleds need.
FF
The throttle bodies on an 800 are behind the engine, not out in front like the 9.
Are you talking about a dubs box?
I run a dubbs - you can even save the radiator if you went with a dubbs, there's just enough clearance. It looks very similar to your custom fab boxexcapt it draws air from the bottom as well via the nosepan screen. I wonder if it could be used on '09 plastic. hmmm....
that is the problem I ran into. The new bumper mounts aren't to friendly with the older airboxes. I think in the end I'm going to be tig'n a new air box that works better.
cheerio.
FF
not having that problem. I put a piece of foam in there so that it keeps the snow from flowing in the whole behind the bumper.
I think I'm going to build a custom air intake and put a stack on it. I've ordered a carbon fiber hood from fast trax and I think it is time to make this sled a bit lighter.
The front radiator wont fit in the 09 plastic.
