2002 MC 800EFI 151 w/ custom painted hood "SOLD"
I bought this sled new, Always stored in insulated garage. Has 10 tooth driver(19 43 gearing) with 8 inch 2 wheels axle in rear. Also with the 10 tooth I did a 2 3/8 set back and installed a 151 in track. RKT 800 head with 13 to 1 or 92 octane at sea level and has 14 to 1 inserts that will come with it. Boysen replacement reeds installed in 2004. Has D&D can and the pipe that will come with it. I did run the pipe for a few years but I needed to run a gallon of race gas because of lean mid. You can run pipe with stock can with no problem(which I still have) or run some race gas like I did. 2 inch powermadd riser, King cat seat. Has re-wound stator at 1700 miles that stator corp re-wound. New fuel pump last year, new TPS in 2008. 2500 miles. I have 5 to 9000 set up in now and will come with above with 9000 and above weights.
https://plus.google.com/u/0/photos/118280509481194022924/albums/5817029986457421937
$2500.00
Location is Sioux Falls SD I work in Iowa (Emmestburg) and can bring it there.
605-941-7155 lbrazil@montagmfg.com
$2500.00
