I have a turbo system for the older style 700 polaris. This came off of a 1999 700 but could be used on any 1997-2000. It uses a Mitsubishi turbo with a Steve Benson mechanical oil pump. The oil pump works great all you have to do is bolt it up to were your old oil injection pump was located. This pump works great. The turbo kit comes with the following parts:
Turbo
Turbo pipe
Boost controller
Oil tank and oil pump
Charge tube, air box
Fuel pump, power jets, Fuel Regulator
Carbs all ready setup with jets and everything they need
Capacitor, rectifier to drive electric fuel pump
Older digitron for a pyrometer and water temp (you will need to get the water temp hook up).
Boost and Fuel pressure guages
Blow off valve for airbox
Hoses, gaskets and a few other things.
Back clutch kit and I will tell you what to put in the front clutch, it is just basic clutching parts that you will probably already have.
Everything will be labeled on were it needs to go so that you can install it on your own sled.
This is the entire turbo system This could be made to work on a 800 Polaris also. This turbo can run between 8-16lbs of boost. Lower boost you can run 50/50 race gas. Anything over 12lbs you need straight race gas. I would like to get $1600 for this system plus shipping. It is well worth the price. You can make your old 700 run very good with this kit.
You can email me at djanderson@dsdmail.net or send me a PM for more info.
Thanks Doug
Turbo
Turbo pipe
Boost controller
Thanks Doug
