swovay696
13 800 Xm. Sled has had a weird miss between 7000-8000 rpm. Nothing horable. Then it started getting worse, and at certain times it would drop down to 7000 rpm, while you have it pinched, and it would stay there as long as as you hold the throttle. Also sounds like it's running on one cylinder when this happens. the last time I rode it, it died as if it blew up, or locked up. Started back up kinda hard, but would run awesome, and have the symptoms, so I limped it to a bar 5 miles away and trailered it. Same symptoms my buddy kinda had on his 14, and his stator was bad. So I put a $100 spi stator, and new plugs in it. Still does it. No codes. Bought it as a holdover, and the dealer said all updates were done. Could it be possible the ecm isn't updated and causing this? Any other ideas? Sled has 1600 miles. Please help. Thanks
Ps I just put a new battery in before I checked for codes, but before I just test ran it. Is it possible that it wouldn't be showing codes right away Even though it's showing symptoms? Sorry for being long winded
