07 m1000 bog, injector error
Mar 14, 2009
51
42
Havre, MT
Have a 07 m1000 keeps bogging down. Has pipe, can boondocker box. Box is showing mag injector error I omed boondocker wiring from injector to box plug in, no open wires. I swapped mag and pto injectors started still shoes mag injector errer. Any other ideas.
tundramonkey
148
MN
Check the wiring for any bare spots or small cracks. Start checking where the wiring is tied down first, then work you way out inch by inch until you find the bad spot.
Sent from my XT1585 using Tapatalk
kiliki
13,214
2,400
Nampa, Idaho
^^ what he said. you have a rubbed wire on that side or a broken wire at the base of the connector
Mar 14, 2009
51
42
Havre, MT
I have taken the boondocker wiring out removed wrap and no rubbed or broken wites. The pto side connector won't hold the pins in it very well but the error keeps showing mag side. Not sure if I'm missing something but looking for ideas.
WyoBoy1000
11,213
3,928
Red Lodge MT to North, CO
No I'm not sure I bought the sled like it is, ran for 2 years and now have this trouble. The shorter wires go to the mag side and longer ones to the pto don't think the short ones are long enough to reach the other side.
Unplug the pto and see what happens on the duty cycle.
I've also heard some of the boxes had backwards wires, have you called bd.
See if you can unplug pto and figure out first if it's hooked up right.
