01 SnoPro W/ Twin Pipes Where To Put Servo And Timing Box?
sprockethead
52
Northern UT
Have some Black Magic pipes to put on a 01 SnoPro and can see this stuff needs to be moved. Where have others with this model sled and twins put them?
Thanks, Sprocket
36
Idaho City, ID
u sound like me 2 years ago...i did this exact same thing and there is no right way of doing it. on mine, i bought a lexan hood and cut the airbox horn off...hard to explain but all in all i ended up making my own airbox using the stock airbox, foam, and glue. also u can cut or remove the servo from the timing box and move each of them into a better location. id also recommend welding a nut on to one pipe to keep the temp sensor.
sprockethead
52
Northern UT
Thanks Cat! Sounds like a pain in the A$$! Do you have any pics of the move? I already have a nut welded to the pipe to retain the exhaust gas temp sensor. Was it worth it to go with the twin pipes?
Sprocket
mountainsnopro
50
51
Flagstaff AZ
I have a 01 SnoPro twin D&D pipes fabcraft 144 2.25 challenger etc.
I made a rubber mounted bracket that mounts the servo up above and slightly forward of the power valves and pipe inlet I have the timing box mounted underneath the pipes on the right side of the front bulkhead. I made a shield slash mounting plate out of aluminum It made for a fairly clean
installation I can try and post some pictures when I get home
