Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 09-11-2018, 11:51 PM
Pcowley1 Pcowley1 is offline
Currently: Not set.
Basic Member
Pcowley1 is an unknown quantity at this point
Default Axys starting issue
Have a 2016 Axys 800 went to fire it up last weekend pulled it over 20 times and nothing. pulled the hood and disconnected the harness and it started first pull so I reconnected the harness and nothing again. has anyone else ran in to this issue if so what caused it. I'm hoping it's not the ecu anyone have any suggestions on what it could be? made sure the key and tether were on.
Thanks
Rate this post: Yes | No
  #2
Old 09-12-2018, 01:02 PM
ripnit ripnit is online now
Currently: working my a$$ off to take time off this winter to RIDE
ripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond repute
Default
???? What do you mean by disconnected the harness, what/ where?
__________________
18 Axys 800, 163, Stock.
16 Axys 800 Snowcheck, Boondocker turbo, kmod, 280 3.5 pitch 163 track.
12 Pro Rmk 800, Boondocker Turbo, 14 motor, 163 Axys 2.6 track.
04 827 RK Tek summit X 144, DJ clutch kit, cc y and pipe, super q can, BR TECH Thrasher side pannels and hood, USI Project X skis, 06 X seat.
  #3
Old 09-12-2018, 01:11 PM
njk4o5 njk4o5 is offline
Currently: Not set.
Basic Member
njk4o5 has a reputation beyond reputenjk4o5 has a reputation beyond reputenjk4o5 has a reputation beyond reputenjk4o5 has a reputation beyond reputenjk4o5 has a reputation beyond reputenjk4o5 has a reputation beyond reputenjk4o5 has a reputation beyond reputenjk4o5 has a reputation beyond reputenjk4o5 has a reputation beyond reputenjk4o5 has a reputation beyond reputenjk4o5 has a reputation beyond repute
Default
mine did the same thing before I put it away for summer. it wouldn't start all of april then I took all the hood stuff off/unplugged stuff and it randomly started one day in july and I drove it into the garage. Now it starts right up with all the stuff unplugged still. I need to figure this out so I don't drive 5 hrs to ride and then have the sled not start
  #4
Old 09-12-2018, 01:20 PM
Default
Ok your talking the hood harness......my bad
__________________
  #5
Old 09-12-2018, 01:26 PM
Teth-Air's Avatar
Teth-Air Teth-Air is online now
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
Default
That plug just feeds the stuff on the hood. My guess would be that the wire to the key switch is shorting to ground or the key switch is not actually opening inside when it is turned on.
__________________
Home of the "Cordless Teth-Air" and NEW "Laser Phantom Teth-Air"
http://www.sourceinnovations.ca
We also have TKI Belt Drives, Arm Candy A-Arm Braces, Oil Tank Inserts, Reversible Scratchers, Polaris Suspension Couplers, Track Clips, Clutching and more.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 800 Strange Starting Issue Thread Starter — DRIVEBYE Forum — Ski-Doo: XM Sleds Replies — 22 Last Post — 12-26-2017 03:29 PM
Thread — bog issue while starting off Thread Starter — stomper Forum — Polaris: GEN 1 and older Replies — 21 Last Post — 01-05-2014 09:14 AM
Thread — Engine Issue/ Starting Thread Starter — duckslayer Forum — Polaris: IQ Replies — 6 Last Post — 01-05-2012 04:50 PM
Thread — Diagnosing Starting Issue - '07 BD TM8 Thread Starter — DeepInTheTrees Forum — Arctic Cat: TURBO Replies — 24 Last Post — 03-25-2011 12:20 AM
Thread — Starting Issue Thread Starter — boondocker97 Forum — Arctic Cat: M Series Replies — 12 Last Post — 01-31-2010 03:46 PM
no new posts
