Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 09-01-2018, 10:36 PM
Colbymh Colbymh is online now
Currently: Staring at my Pro
Colbymh has a reputation beyond reputeColbymh has a reputation beyond reputeColbymh has a reputation beyond reputeColbymh has a reputation beyond reputeColbymh has a reputation beyond reputeColbymh has a reputation beyond reputeColbymh has a reputation beyond reputeColbymh has a reputation beyond reputeColbymh has a reputation beyond reputeColbymh has a reputation beyond reputeColbymh has a reputation beyond repute
Default Gates belt vs polaris
Anyone running a gates kevlar or carbon fiber belt as a spare? I’m tempted to order one versus another polaris #3211183.
Rate this post: Yes | No
  #2
Old 09-02-2018, 03:27 AM
prorideupper800 prorideupper800 is offline
Currently: waiting for the Big Snow maker to give us some Powder inthebackcountry of theUPehh
prorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond repute
Garage
Default
Yes excellent Belt no Polaris belt for me no more only Gates Carbon over 3500 miles and have yet to blow one on my 16 SKS now with 8400 miles with no rebuilds, 911 clutch cover from Thunder products best investment ever made.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 09-02-2018, 04:32 AM
Default
Good to know. Ordered.
  #4
Old 09-02-2018, 11:42 AM
Spaarky's Avatar
Spaarky Spaarky is online now
Currently: Moved Into Maximum Security Cell
Spaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond repute
Default
I would use Gates as primary. Polaris as back up. Don’t fold the Gates. It’s a couple hundred rpm pick up when you put it on.
  #5
Old 09-03-2018, 06:49 AM
SRXSRULE SRXSRULE is offline
Currently: Not set.
SRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond repute
Default
Gates carbon = Primary
Polaris = Spare
As mentioned, dont fold the gates belt in half, and try real hard to break it in correctly. I like to get 3 heat cycles in a new belt before putting full load on it.
Buy 2 new belts, go for an easy ride and swap them out every 10 minutes. Basically all you need to do is get the belt fully up to operating temp, and allow it to cool down, then repeat.
  #6
Old 09-03-2018, 08:07 AM
Ratchit Ratchit is offline
Currently: just going with the flo
Ratchit has a reputation beyond reputeRatchit has a reputation beyond reputeRatchit has a reputation beyond reputeRatchit has a reputation beyond reputeRatchit has a reputation beyond reputeRatchit has a reputation beyond reputeRatchit has a reputation beyond reputeRatchit has a reputation beyond reputeRatchit has a reputation beyond reputeRatchit has a reputation beyond reputeRatchit has a reputation beyond repute
Default
The gates is about 0.030” thicker then the Polaris belt too.
  #7
Old 09-03-2018, 11:15 AM
Default
u lost me on the bending in half part. Who folds them in half to store them amd why would u even do that? Im not sure ill swap every 10 mins but break in heat cyles, stop and let it cool down yes.
  #8
Old 09-03-2018, 12:00 PM
gtwitch gtwitch is online now
Currently: Not set.
gtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond repute
Default
I think they are talking about how you carry your spare on the machine!! On my modded PRO they are basically folded in half in the spare belt carrier and this can cause some problem if you carry a new Gates carbon in there, so I have a different method for that and I also only carry a POO belt for a spare if I have one, so that is not a problem in my case. I had two and one half years and about 2200 miles on my last Gates carbon when it blew some of the inside edge parts out of it and put the poo spare on for about 200 miles until my order of 3 new Gates came in (from Dobeck) and then finished last season on the new Gates. As was said above, break in is paramount. I have run the Gates belts for last 7 years with no problems or complaints at all and we have 5 Polaris from 07-700 Dragon 155 up to new 18 axys and all of the 4- 163's are 800's. suggestion here-- Start the machine and bring the sled up to temp and with sled raised --cycle the clutches, belt and track up in speed over the off season! I do this at least twice during the summer months.
gtwitch in wyoming
  #9
Old 09-03-2018, 01:52 PM
Default
Normally I would just vary throttle 3/4 and under for 10-15 then let it cool a few times. First 3 hours pretty relaxed and variable in throttle and after that its go time.
I run mine for a min or 2 every week or so right now. Is there any other method with the gates belt I should do?
  #10
Old 09-04-2018, 04:25 PM
Havesledwilltravel Havesledwilltravel is offline
Currently: Wanting to ride
Basic Member
Havesledwilltravel has a reputation beyond reputeHavesledwilltravel has a reputation beyond reputeHavesledwilltravel has a reputation beyond reputeHavesledwilltravel has a reputation beyond reputeHavesledwilltravel has a reputation beyond reputeHavesledwilltravel has a reputation beyond reputeHavesledwilltravel has a reputation beyond reputeHavesledwilltravel has a reputation beyond reputeHavesledwilltravel has a reputation beyond reputeHavesledwilltravel has a reputation beyond reputeHavesledwilltravel has a reputation beyond repute
Default
Off brand but I have 1600mi on my gates installed on my XM, and OEM as spare. When I get my new snowcheck SKS 850 I will be doing the same thing if a belt available.
  #11
Old 09-05-2018, 06:38 AM
Click Here to Register
  #12
Old 09-05-2018, 10:42 PM
goontwo goontwo is offline
Currently: 13 Pro 163
goontwo is an unknown quantity at this point
  #13
Old 09-05-2018, 11:21 PM
  #14
Old 09-06-2018, 06:54 AM
GoBigParts's Avatar
GoBigParts GoBigParts is offline
Currently: Not set.
GoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond repute
  #15
Old 09-06-2018, 08:39 AM
Teth-Air's Avatar
Teth-Air Teth-Air is online now
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
  #16
Old 09-20-2018, 05:13 AM
GoBigParts's Avatar
Currently: Not set.
  #17
Old 09-20-2018, 05:44 AM
FatDogX's Avatar
FatDogX FatDogX is offline
Currently: ND. Meatball Crew / Polaris Ambassador
FatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond repute
  #18
Old 09-20-2018, 11:26 AM
Wheel House Motorsports's Avatar
Wheel House Motorsports Wheel House Motorsports is online now
Currently: is it winter yet?
Wheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond repute
  #19
Old 09-20-2018, 02:15 PM
powkat powkat is offline
Currently: Not set.
powkat is an unknown quantity at this point
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Tired of Expensive Polaris Belts? GATES G FORCE C12 CARBON DRIVE BELT Thread Starter — GoBigParts Forum — Polaris: Pro-Ride Replies — 24 Last Post — 11-12-2018 06:11 AM
Thread — Gates Drive Belt for 2011-2015 Polaris Pro RMK (44C4553) Thread Starter — XFIRE800 Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 0 Last Post — 03-10-2017 11:45 AM
Thread — Gates belt # Thread Starter — m8braaaap Forum — Arctic Cat: Proclimb M Replies — 21 Last Post — 02-12-2017 12:01 PM
Thread — Gates G Force Gates belt - Backup? Thread Starter — Golanda Forum — Polaris: AXYS Replies — 4 Last Post — 08-30-2015 03:45 PM
Thread — Gates belt to replace the 377 xp belt Thread Starter — mt.sledder Forum — Ski-Doo Replies — 17 Last Post — 02-03-2009 07:05 PM
no new posts
