Upgrade to Premium
Reply
  #1
Old 08-15-2018, 12:55 PM
needpowder's Avatar
needpowder needpowder is online now
Currently: dreaming of global cooling
needpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond repute
Default CMX track for timbersled
Pulled the trigger on the new CMX track this morning. Mark said it should be at my house by Friday ��. I am going to put this track on my 16 timber sled kit. 137 inch. Obviously I will half to cut some notches for the chain. I’m just wondering what the best tool would be for this? Anyone have any experience?
__________________
2016 YZ450fx w/16 TS LT
Rate this post: Yes | No
  #2
Old 08-15-2018, 03:32 PM
tek9tim tek9tim is offline
Currently: Not set.
Basic Member
tek9tim has a reputation beyond reputetek9tim has a reputation beyond reputetek9tim has a reputation beyond reputetek9tim has a reputation beyond reputetek9tim has a reputation beyond reputetek9tim has a reputation beyond reputetek9tim has a reputation beyond reputetek9tim has a reputation beyond reputetek9tim has a reputation beyond reputetek9tim has a reputation beyond reputetek9tim has a reputation beyond repute
Default
Maybe this?
https://www.amazon.com/Original-Knob.../dp/B00H3QJ5PA
  #3
Old 08-15-2018, 05:31 PM
needpowder's Avatar
Default
Hmm...I have been kind of wanting one of those for my dirtbike tires. I wonder how wide the tip is. I could use a bandsaw and cut two vertical cuts and then use that for the horizontal cut if it’s not too wide possibly.
__________________
  #4
Old 08-15-2018, 08:34 PM
UPsnowbiker UPsnowbiker is online now
Currently: Not set.
UPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond reputeUPsnowbiker has a reputation beyond repute
Default
Please update us on the install and any issues or tips. Plan on doing the exact same thing
  #5
Old 08-16-2018, 09:12 AM
M5- M5- is offline
Currently: Planning a build
Basic Member
M5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond repute
Default
The knobby cutting tool is the right idea. You can buy soldering irons in all different wattages for pretty cheap. I bought a big one for my sons girlfriend she makes leather stuff and has a custom stamp. It was pretty cheap. Check out HF pick up a 120 watt or so and make a custom tip for it.
I'm going to put that track on my TS as well just deciding on 137 or 129, I'm leaning towards the 137 because I already have 137 Iceage rails.
M5
  #6
Old 08-16-2018, 09:35 AM
needpowder's Avatar
Default
M5, thanks. I will try to swing by Harbor freight today and see what they have. I also wanted to ask you about changing bearings. Three years on my kit and I haven’t touched them! I am pretty much going to be disassembling my kit since I need to straighten one of the panels as well as change the track so figured I might as well do the bearings. I should change all four right? In an earlier thread you were talking SKF bearings. https://www.snowest.com/forum/showth...light=Bearings
Is this still your recommendation?
__________________
  #7
Old 08-16-2018, 10:27 AM
Grr Grr is online now
Currently: Not set.
Basic Member
Grr has a reputation beyond reputeGrr has a reputation beyond reputeGrr has a reputation beyond reputeGrr has a reputation beyond reputeGrr has a reputation beyond reputeGrr has a reputation beyond reputeGrr has a reputation beyond reputeGrr has a reputation beyond reputeGrr has a reputation beyond reputeGrr has a reputation beyond reputeGrr has a reputation beyond repute
Default
That knobby cutting tool is garbage on tracks I bought one and couldn’t do jack with it. What works the best is a utility blade or razor blades by far. I’ve done tons of lug cutting and this is 100% 5e best. The knob cutter didn’t work at all and good luck getting straight cuts
I normally use utility blades and a vice grip. Now I have a heavy belting cutter that is basically an oversized orange box cutter with snap off blade sections
The Following User Says Thank You to Grr For This Useful Post:
needpowder (08-16-2018)
  #8
Old 08-16-2018, 01:30 PM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: Getting the R6 snowbike ready......
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
Default
Utility knife with a little lube on the blade.
Swap blades often.
__________________
Try again
  #9
Old 08-16-2018, 01:33 PM
Default
12” wide convex 155x3
Sent from my iPhone using Tapatalk Pro
__________________
Try again
The Following User Says Thank You to Sheetmetalfab For This Useful Post:
  #10
Old 08-16-2018, 02:30 PM
needpowder's Avatar
  #11
Old 08-16-2018, 03:39 PM
Click Here to Register
  #12
Old 08-16-2018, 06:43 PM
coryf89 coryf89 is offline
Currently: 13 ktm 450sxf. 17 yeti 129
Basic Member
coryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond repute
The Following User Says Thank You to coryf89 For This Useful Post:
needpowder (08-17-2018)
  #13
Old 08-17-2018, 08:25 AM
M5- M5- is offline
Basic Member
The Following User Says Thank You to M5- For This Useful Post:
  #14
Old 08-17-2018, 01:17 PM
needpowder's Avatar
  #15
Old 08-17-2018, 04:09 PM
  #16
Old 08-17-2018, 06:20 PM
needpowder's Avatar
The Following 3 Users Say Thank You to needpowder For This Useful Post:
Grr (08-18-2018), Sheetmetalfab (08-17-2018), wwillf01 (08-17-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — New CMX track reviews?? Thread Starter — El Gringo Forum — Snow bikes Replies — 73 Last Post — 04-10-2018 10:50 PM
Thread — CMX Track and 129 Rail Extensions Thread Starter — UPsnowbiker Forum — Snow bikes Replies — 16 Last Post — 03-16-2018 05:15 PM
Thread — CMX track Thread Starter — RMK935VA Forum — Snow bikes Replies — 24 Last Post — 01-31-2018 08:57 AM
Thread — Timbersled or CMX Thread Starter — Radski30 Forum — Snow bikes Replies — 50 Last Post — 10-29-2015 12:04 PM
Thread — CMX 1085 w/ 162 track and 2 extra hoods Thread Starter — Revanator Forum — Misc. Brands (Swapmeet) Replies — 14 Last Post — 08-16-2010 01:30 PM
no new posts
