Upgrade to Premium
Ski-Doo: REV Gen 4 For the 2017 and newer REV Gen 4 Sleds
Reply
  #1
Old 04-19-2018, 11:16 AM
bcpowder bcpowder is offline
Currently: Not set.
Basic Member
bcpowder has a reputation beyond reputebcpowder has a reputation beyond reputebcpowder has a reputation beyond reputebcpowder has a reputation beyond reputebcpowder has a reputation beyond reputebcpowder has a reputation beyond reputebcpowder has a reputation beyond reputebcpowder has a reputation beyond reputebcpowder has a reputation beyond reputebcpowder has a reputation beyond reputebcpowder has a reputation beyond repute
Default 850 Belt life - A band aid Journey
Hi team,
Just to follow up on this post i originally put up with my 2017 850 (link below): I figured I'd give some history, and my thoughts on the My2019 belt life updates.
https://www.snowest.com/forum/showthread.php?t=432597
Following the post above, I did get my alignment corrected, and it delivered no improvement to my belt life. I think it actually got worse. I ended up trading my 2017 in for a 2018 850 which obviously had the My2018 belt life upgrades. This delivered some improvement to belt life, but it was still totally disappointing.
I would say the My2018 updates took me from 100km per belt to 200 km per belt.
On the 2018 sled my alignment was spot on. I can confidently say that this is not the global issue with this sled, although it may be a compounding issue on some sleds. I spent considerable time playing with different clutch calibrations to see if we could refine shift consistency to stabilize peak rpm, minimize over rev, and improve back shift. I would say this process got me closer to 300 km per belt.
For all those wanna be sled mechanics out there, we don't need your thoughts on belt deflection, or belt break in procedure.
My opinion after running hard at belt issues on 2 years of these selds, is that the fundamental issue is excessive engine movement / vibration due to the long stroke 850. BRP is trying hard to counter act this with their "wobble clutch", and continually stiffening motor mounts in each years Belt life updates.
unfortunately, upon watching the unveiling of the MY2019 belt life upgrades, I've had to move on to a mountain cat as BRP has only confirmed to me that there is no way to correct the vibration in the 850 power plant...only band aids to put over top of it.
As can be seen in the 2019 updates, BRP is again stiffening motor mounts, however it clearly doesn't solve the base issue of excessive motor vibration. This which is confirmed by the fact that their second update is a fan clutch and radical air movement technology to run past the clutches to deal with what they know is excessive heat being generated by the engine vibration. The 3rd update of the belt guard is nothing more than a distraction, which is confirmed by them in their roll out and not a wide spanning issue.
At the end of the day, if you ride the 2019 850 hard in the mountains, i would predict 200-400 km per belt. The regular rider may be able to get around 1000-2000 km. The disappointing part here is that on the xm, these same riders now getting 1000 - 2000km, used to get 3000 - 5000 km per belt. BRP will isolate the hard riders and rider blame, and eventually you will be on your own with an under performing machine, paying for belts, and dealing with the compounding wear and tear of a constantly overheated and shock loaded crank.
Good luck boys.
Last edited by bcpowder; 04-19-2018 at 11:17 AM. Reason: SKidoo belt life, alignment, vibration, 850 etec summit
4 out of 6 members found this post helpful. Rate this post: Yes | No
The Following 3 Users Say Thank You to bcpowder For This Useful Post:
freekweet mods (04-20-2018), rulonjj (04-21-2018), yamikilr (04-19-2018)
  #2
Old 04-19-2018, 12:17 PM
BILTIT's Avatar
BILTIT BILTIT is online now
Currently: Never enough snow!!!
BILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond repute
Default
Sorry to hear about the mountain cat...
All kidding aside, good to hear some honest info/thoughts/opinions.
Sent from my SM-G925W8 using Tapatalk
__________________
Derek B.
2000 440 xc sp 136 (EDGE)
2003 800 RMK 162
2004 910 PRO-XR 121x1.75", Wheelie Machine!!!
2011 LRod 13.6 800 ProRMK 3"PC KMOD/Raptors kmod 37" arms Ti can
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to BILTIT For This Useful Post:
DDECKER (04-20-2018)
  #3
Old 04-19-2018, 04:32 PM
sledhead_24_7's Avatar
sledhead_24_7 sledhead_24_7 is offline
Currently: pow hunting on the 850
sledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond repute
Default
You are most likely right, unfortunately. Which most likely put me on a Alpha Cat or dare I say a Pro 850 in the next year or 2.
I also had 2 model years of 850 blown belt issues. 14 belts between the 17,and 18 both around the 850-950 mile mark.
Band aids on a chassis flaw to cover over the flaw, does not fix the flaw obviously.
__________________
2018 Summit X 850 175X3"
  #4
Old 04-19-2018, 05:22 PM
DITCHBANGER's Avatar
DITCHBANGER DITCHBANGER is online now
Currently: Garage Riding
DITCHBANGER has a reputation beyond reputeDITCHBANGER has a reputation beyond reputeDITCHBANGER has a reputation beyond reputeDITCHBANGER has a reputation beyond reputeDITCHBANGER has a reputation beyond reputeDITCHBANGER has a reputation beyond reputeDITCHBANGER has a reputation beyond reputeDITCHBANGER has a reputation beyond reputeDITCHBANGER has a reputation beyond reputeDITCHBANGER has a reputation beyond reputeDITCHBANGER has a reputation beyond repute
Default
Alpha cat is tempting, buddy just ordered one, doo is on the 3rd year and still doing updates to a problem that should have never been a problem from the get go.
The Following User Says Thank You to DITCHBANGER For This Useful Post:
sledhead_24_7 (04-19-2018)
  #5
Old 04-19-2018, 06:23 PM
Illinoispowder Illinoispowder is offline
Currently: Not set.
Basic Member
Illinoispowder has a reputation beyond reputeIllinoispowder has a reputation beyond reputeIllinoispowder has a reputation beyond reputeIllinoispowder has a reputation beyond reputeIllinoispowder has a reputation beyond reputeIllinoispowder has a reputation beyond reputeIllinoispowder has a reputation beyond reputeIllinoispowder has a reputation beyond reputeIllinoispowder has a reputation beyond reputeIllinoispowder has a reputation beyond reputeIllinoispowder has a reputation beyond repute
Default Belt life
If engine mounts are the "real" issue, why did the 2017 trail sleds with soft mounts have a much lower failure rate? Proper clutch calibration is needed (which shouldn't be a big deal), and proper venting, which all sleds need. The biggest issue I believe, is alignment under load. How do you know your alignment is spot on under load? How do you know if it's in spec at rest when the fixed sheave has .024 run-out built in?
The Following User Says Thank You to Illinoispowder For This Useful Post:
Daag44 (04-30-2018)
  #6
Old 04-19-2018, 06:41 PM
Clutched Films's Avatar
Clutched Films Clutched Films is offline
Currently: Not set.
Clutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond repute
Default Jumping ship kinda
This is why I snow checked 2019 Alpha1 & 2019 850 Freeride 137" with shot. I really liked the 850 chassis / power ish but I have to spend time and money just to get it to run with my buddy's 2018 Arctic Cat 800. I think the motor has more power then the Cats she's just losing way to much from crank-track. We road that Alpha1 and it smoked my 850 head to head up the hill and the Alpha1 was still in break in. No messing with clutching & the shocks don't need to be replaced before riding. I'm a diehard Ski-Doo rider or at least was haha. Sad to say but that cat just works better for me with the power & handling on the hill. Can't wait to come back to Ski-Doo once they get it figured out. Still love Doo that's why I got me that 850 Freeride 137" with shot love me that shot haha. You should have seen the disappointment in my father haha.
The Following 2 Users Say Thank You to Clutched Films For This Useful Post:
rulonjj (04-21-2018), summ8rmk (04-19-2018)
  #7
Old 04-19-2018, 07:01 PM
Adam12's Avatar
Adam12 Adam12 is offline
Currently: Waiting for winter
Adam12 has a reputation beyond reputeAdam12 has a reputation beyond reputeAdam12 has a reputation beyond reputeAdam12 has a reputation beyond reputeAdam12 has a reputation beyond reputeAdam12 has a reputation beyond reputeAdam12 has a reputation beyond reputeAdam12 has a reputation beyond reputeAdam12 has a reputation beyond reputeAdam12 has a reputation beyond reputeAdam12 has a reputation beyond repute
Default
Quote:
Originally Posted by Clutched Films View Post
This is why I snow checked 2019 Alpha1....
Man, I hope we get some more rides in next year. I wanna see that thing.
__________________
2018 Summit 850 165"
  #8
Old 04-20-2018, 04:50 AM
apex 9420t apex 9420t is offline
Currently: Not set.
Basic Member
apex 9420t has a reputation beyond reputeapex 9420t has a reputation beyond reputeapex 9420t has a reputation beyond reputeapex 9420t has a reputation beyond reputeapex 9420t has a reputation beyond reputeapex 9420t has a reputation beyond reputeapex 9420t has a reputation beyond reputeapex 9420t has a reputation beyond reputeapex 9420t has a reputation beyond reputeapex 9420t has a reputation beyond reputeapex 9420t has a reputation beyond repute
Default
Wow getting smoked by cats. Something I just haven't seen and I ride with a lot of 18 mtn cats something must be wrong with your 850
  #9
Old 04-20-2018, 10:37 AM
Currently: Not set.
Basic Member
Default
Quote:
I think the engine mounts are an attempt to tame the real issue of engine vibration. I don't think the mounts are the "real" issue.
The alignment spec is +/- 1.8mm. .024inches is 0.6mm. with that being said, you can take measurements at a few rotation spots, and take the mean value.
To answer your question about alignment under load, all I can do is ensure the machine is set to spec, with the front dimension being 3mm greater than the rear to accommodate the movement when loaded.
BRP is full of very smart people. If the fix to all their problems was simply an alignment fix under load through motor mounts...it would have been solved last year in the MY2018 Belt life updates. The new mounts for 2019 will be stiffer, and will pull out some more vibration from the belt, but it won't be enough in my opinion.
  #10
Old 04-20-2018, 12:11 PM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
Here's where I think BRP overthought the whole clutch/belt relationship...
The engineered primary clutch "wobble" to offset engine reciprocation in the up/down axis is a great idea. BUT... The amount of sheave wobble is fixed. The amount of engine movement is variable. ONLY when the engine movement matches the "engineered" amount of movement will the "wobble" work as intended. At ALL other times the primary sheave will be acting similar to excessive crank run-out and basically be scrubbing the belt. This will massively increase temps and shorten belt life.
Even with the proper motor mount hardness, when the belt is under more (or less) tension between the 2 clutches, this will also effect how much up/down movement the engine will see as it pulls on the mounts. Again....varying the relationship between the wobble and engine movement which must be stable and consistent to be effective.
They need to stabilize the engine and eliminate the sheave wobble design unless they can guarantee a consistent amount of engine movement regardless of RPM, engine output, belt tension and motor mount condition. I don't see that as being possible.
5 out of 5 members found this post helpful. Rate this post: Yes | No
The Following 9 Users Say Thank You to winter brew For This Useful Post:
BIG JOHN (04-21-2018), blastco2 (05-28-2018), Blk88GT (04-20-2018), freekweet mods (04-22-2018), Matte Murder (04-21-2018), MountainTrashCat (04-21-2018), Ol Boondocker (05-03-2018), PaulAnd (04-20-2018), White Rad (04-22-2018)
  #11
Old 04-20-2018, 05:26 PM
Ski-doo#1 Ski-doo#1 is offline
Currently: Not set.
Basic Member
Ski-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond repute
Click Here to Register
  #12
Old 04-20-2018, 06:15 PM
Daag44 Daag44 is offline
Currently: Not set.
Basic Member
Daag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond repute
The Following User Says Thank You to Daag44 For This Useful Post:
Ski-doo#1 (04-24-2018)
  #13
Old 04-21-2018, 11:12 AM
clutch clutch is offline
Currently: WTF mother nature?
Basic Member
clutch has a reputation beyond reputeclutch has a reputation beyond reputeclutch has a reputation beyond reputeclutch has a reputation beyond reputeclutch has a reputation beyond reputeclutch has a reputation beyond reputeclutch has a reputation beyond reputeclutch has a reputation beyond reputeclutch has a reputation beyond reputeclutch has a reputation beyond reputeclutch has a reputation beyond repute
  #14
Old 04-21-2018, 11:17 AM
Matte Murder Matte Murder is offline
Currently: Great season with friends this year!
Matte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond repute
The Following 2 Users Say Thank You to Matte Murder For This Useful Post:
Daag44 (04-21-2018), MountainTrashCat (04-21-2018)
  #15
Old 04-21-2018, 08:09 PM
Currently: Not set.
Basic Member
  #16
Old 04-21-2018, 11:41 PM
White Rad's Avatar
White Rad White Rad is offline
Currently: Waiting for Ski Doo Warranty
White Rad has a reputation beyond reputeWhite Rad has a reputation beyond reputeWhite Rad has a reputation beyond reputeWhite Rad has a reputation beyond reputeWhite Rad has a reputation beyond reputeWhite Rad has a reputation beyond reputeWhite Rad has a reputation beyond reputeWhite Rad has a reputation beyond reputeWhite Rad has a reputation beyond reputeWhite Rad has a reputation beyond reputeWhite Rad has a reputation beyond repute
The Following 3 Users Say Thank You to White Rad For This Useful Post:
d8grandpa (05-07-2018), sledhead_24_7 (04-22-2018), Wheel House Motorsports (05-01-2018)
  #17
Old 04-22-2018, 08:06 AM
White Rad's Avatar
The Following User Says Thank You to White Rad For This Useful Post:
  #18
Old 04-22-2018, 10:19 AM
Chadly's Avatar
Chadly Chadly is offline
Currently: Not set.
Chadly has disabled reputation
The Following 2 Users Say Thank You to Chadly For This Useful Post:
Daag44 (04-22-2018), Ski-doo#1 (04-24-2018)
  #19
Old 04-22-2018, 01:10 PM
jvb jvb is offline
Currently: Not set.
jvb has a reputation beyond reputejvb has a reputation beyond reputejvb has a reputation beyond reputejvb has a reputation beyond reputejvb has a reputation beyond reputejvb has a reputation beyond reputejvb has a reputation beyond reputejvb has a reputation beyond reputejvb has a reputation beyond reputejvb has a reputation beyond reputejvb has a reputation beyond repute
  #20
Old 04-22-2018, 03:11 PM
Yella Belly's Avatar
Yella Belly Yella Belly is offline
Currently: Where o where did all the snow go??.
Yella Belly has a reputation beyond reputeYella Belly has a reputation beyond reputeYella Belly has a reputation beyond reputeYella Belly has a reputation beyond reputeYella Belly has a reputation beyond reputeYella Belly has a reputation beyond reputeYella Belly has a reputation beyond reputeYella Belly has a reputation beyond reputeYella Belly has a reputation beyond reputeYella Belly has a reputation beyond reputeYella Belly has a reputation beyond repute
The Following User Says Thank You to Yella Belly For This Useful Post:
  #21
Old 04-22-2018, 06:03 PM
BIG C BIG C is offline
Currently: Watching it melt!
Basic Member
BIG C has a reputation beyond reputeBIG C has a reputation beyond reputeBIG C has a reputation beyond reputeBIG C has a reputation beyond reputeBIG C has a reputation beyond reputeBIG C has a reputation beyond reputeBIG C has a reputation beyond reputeBIG C has a reputation beyond reputeBIG C has a reputation beyond reputeBIG C has a reputation beyond reputeBIG C has a reputation beyond repute
The Following 2 Users Say Thank You to BIG C For This Useful Post:
  #22
Old 04-22-2018, 07:38 PM
paulharris paulharris is offline
Currently: want pow
paulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond repute
  #23
Old 04-23-2018, 08:46 PM
White Rad's Avatar
The Following 5 Users Say Thank You to White Rad For This Useful Post:
justinkredible56 (04-25-2018), paulharris (04-24-2018), sledhead_24_7 (04-24-2018), summ8rmk (04-23-2018), Wheel House Motorsports (05-01-2018)
  #24
Old 04-23-2018, 09:00 PM
i'llDooit i'llDooit is offline
Currently: summer sucks
i'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond repute
The Following User Says Thank You to i'llDooit For This Useful Post:
rightjake (05-07-2018)
  #25
Old 04-23-2018, 10:36 PM
White Rad's Avatar
The Following 7 Users Say Thank You to White Rad For This Useful Post:
bkm20x (04-24-2018), Clark42 (04-24-2018), d1100t (04-24-2018), duggrant (04-26-2018), no_uh (04-25-2018), sledhead_24_7 (04-24-2018), Snowmow (04-24-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — G4 BELT EATER! [2017 Ski Doo 850 Rev G4 clutching/belt fix?] Belt Issues Thread Starter — NWaxys Forum — Ski-Doo: REV Gen 4 Replies — 229 Last Post — 06-10-2017 06:15 AM
Thread — anybody used infared belt temp gauge for belt life Thread Starter — mavman Forum — Ski-Doo: XM Sleds Replies — 2 Last Post — 09-25-2015 08:21 AM
Thread — wide band O2 sensor life Thread Starter — pura vida Forum — Polaris: Pro-Ride Replies — 19 Last Post — 12-27-2011 08:23 PM
Thread — 09 xp belt life Thread Starter — f7nomore Forum — Ski-Doo Replies — 22 Last Post — 03-20-2011 05:53 PM
Thread — Belt-Aid WTB Thread Starter — MC 144 Forum — Misc. Snowmobile (Swapmeet) Replies — 0 Last Post — 01-21-2009 10:40 PM
