Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 04-08-2018, 04:21 PM
Skirby Skirby is offline
Currently: Not set.
Basic Member
Skirby is an unknown quantity at this point
Default Leak down test 600
Working on a 15 600 Indy sp thatís blown up. Trying to figure out what caused it to burn down. Exhaust and reed boots are capped and I lose air faster than I can put it in. Is there anywhere other place I could be losing air? Canít be a pulse line with injectors. I havenít pulled the engine yet hoping the case isnít cracked
Rate this post: Yes | No
  #2
Old 04-08-2018, 07:23 PM
volcano buster volcano buster is offline
Currently: Not set.
volcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond repute
Default
Does it still have water in it? Forcing air into it with a leaky head seal would pressurize the coolant system.
I'm guessing a ring is allowing the blow by. I had a broken ring on mine and it ended up eating the transfer port.
  #3
Old 04-09-2018, 04:57 AM
Currently: Not set.
Basic Member
Default
It still has the water in so I should be able to build pressure with the cap on the reservoir or at least get bubbles in the water. Ring leaks donít matter since you pressurize the whole engine cavity. I can hear air leak out and canít pin point it with the engine in the sled still. I was hoping I missed a line or something and thatís where the air is going
  #4
Old 04-13-2018, 09:37 PM
peaceofwork peaceofwork is offline
Currently: Internet Rmkpro 800apprentiship
Basic Member
peaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond repute
Default
Have you sealed off the power valves with sealed block off plates ? After the intake boots and exhaust are covered warm soapy water should pin point any leak fast.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — KK leak down test Thread Starter — WAMort Forum — Arctic Cat: 1M Replies — 0 Last Post — 11-24-2011 09:58 AM
Thread — Leak Down Test? Thread Starter — SpeedWobble Forum — Polaris: Pro-Ride Replies — 9 Last Post — 05-28-2011 10:36 AM
Thread — How to do a boost leak test Thread Starter — zebiraross Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 7 Last Post — 09-16-2009 06:30 PM
Thread — Leak Down Test ? Thread Starter — JOP Forum — Yamaha Replies — 9 Last Post — 07-26-2009 12:30 PM
