P
- How can you tell your ECU is the issue?
- Is there testing that can be done without a DW?
I'm working with a 2008 700 Dragon, it runs fantastic, sounds strong. My issue is high idle, 3200rpm's yeah kind of a lot.
What have I done to remedy?
- cleaned throttle body
- replaced throttle body boots
- cleaned reeds
- cleaned and rebuilt exhaust valves
- replaced o-rings on injectors
- sensors tested
- coolant
- air intake
- exhaust
- TPS
- reset the TPS .7 base, .95 idle
- throttle cable slack
- brake clean test for vacuum leaks
I'm leaning towards the ECU, no?
Is it possible that it's reading the sensors incorrectly.
- cleaned reeds
- sensors tested
- coolant
- air intake
- exhaust
- TPS
