Upgrade to Premium
Ski-Doo: REV Sleds 2004.5-200, all models in the REV chassis
Reply
  #1
Old 03-19-2018, 04:54 PM
Aksnowman89 Aksnowman89 is offline
Currently: Not set.
Basic Member
Aksnowman89 is an unknown quantity at this point
Default how to use reverse without battery in electric start model
I have a 2007 800r PTEK summit x and I would really like to get my reverse to work. The person I bought it from had removed the battery and starter. I was wondering if there was a way to get the reverse to work on this sled without all of that. Any help is appreciated.
Rate this post: Yes | No
  #2
Old 03-21-2018, 02:37 PM
cubby's Avatar
cubby cubby is offline
Currently: Riding Atv's till the snow comes back
cubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond repute
Default
You don't need electric power to run the reverse. Just start the sled and let it warm up and hit the button, should work no problem even without electric start.
__________________
2016 T3 154"
2007 XRS 800 151" engine built by SHR
2013 Polaris 850xp
2015 Polaris 1000xp
2016 Polaris 170 RZR
Hold it pinned till you feel bad
  #3
Old 03-22-2018, 10:53 AM
NEWDUCK NEWDUCK is offline
Currently: one ski dreams
Basic Member
NEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond repute
Default
You need a new wire harness from a non e start sled. Not the entire harness but just a section. I dont know why the battery is wired into the harness but if I dont have a battery in mine it causes all sorts of havoc.
  #4
Old 03-22-2018, 05:34 PM
Ox's Avatar
Ox Ox is offline
Currently: New sled and ready to roll!
Ox has disabled reputation
Default
Is this fuel infected or does it have a cardboard meter?
Directed at both post 1 and 3.
  #5
Old 03-26-2018, 08:29 AM
Basic Member
Default
Not injected.
  #6
Old 03-30-2018, 05:59 PM
treeboy treeboy is online now
Currently: Not set.
Basic Member
treeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond repute
Default
Quote:
X2 what cubby said. You don’t need the battery for reverse, or change your wire harness. All the battery does is start the machine.
  #7
Old 03-31-2018, 10:00 AM
Basic Member
Default
I highly disagree. The rev needs the battery to function. Remove it and odd things start happening. Replace the wire harness with a non e start and you are good to go.
  #8
Old 04-09-2018, 01:35 PM
rheinss10 rheinss10 is offline
Currently: Not set.
rheinss10 has a reputation beyond reputerheinss10 has a reputation beyond reputerheinss10 has a reputation beyond reputerheinss10 has a reputation beyond reputerheinss10 has a reputation beyond reputerheinss10 has a reputation beyond reputerheinss10 has a reputation beyond reputerheinss10 has a reputation beyond reputerheinss10 has a reputation beyond reputerheinss10 has a reputation beyond reputerheinss10 has a reputation beyond repute
Default
You need the relay harnessthat goes between the main wiring harness and the cube relay located on the section of the pyramid frame directly above the secondary clutch. Doo had a relay harness for e-start models and one for sleds that didn't have e-start.
Also if reverse isn't working try changing the relay. If previous owner removed e-start and didn't change relay harness the sled would not run w/o battery. Most likely your reverse not working is due to a bad relay.
Click image for larger version
Name:	Screenshot_20180409-143438_Samsung Internet.jpg
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to rheinss10 For This Useful Post:
cubby (04-10-2018)
Reply
Bookmarks
Tags
rer
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Battery warning on non Electric start Thread Starter — kidwoo Forum — Arctic Cat: Proclimb M Replies — 11 Last Post — 03-17-2018 04:51 PM
Thread — Low Battery Sensor?...Non-Electric Start Thread Starter — KGMT2013 Forum — Ski-Doo: XM Sleds Replies — 1 Last Post — 01-08-2013 10:10 AM
Thread — electric start and battery Thread Starter — kai Forum — Misc. Sled Parts Replies — 1 Last Post — 03-19-2010 06:45 PM
Thread — New for 2010, battery less electric start! Thread Starter — Moosedog Forum — Arctic Cat: M Series Replies — 3 Last Post — 10-21-2009 09:05 AM
Thread — HELP!! Electric Start Battery Thread Starter — efulton Forum — Polaris Replies — 3 Last Post — 12-03-2008 09:59 AM
no new posts
