Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 03-15-2018, 12:38 AM
thump426er's Avatar
thump426er thump426er is offline
Currently: Not set.
thump426er has a reputation beyond reputethump426er has a reputation beyond reputethump426er has a reputation beyond reputethump426er has a reputation beyond reputethump426er has a reputation beyond reputethump426er has a reputation beyond reputethump426er has a reputation beyond reputethump426er has a reputation beyond reputethump426er has a reputation beyond reputethump426er has a reputation beyond reputethump426er has a reputation beyond repute
Default HIGH MILEAGE TURBO??
Hey there Iíve got a 2016 axys 163-3Ē with approximately 3500 miles on it. New top end about to go in.
If I donít check a new 850 Iím considering throwing a turbo on the 16. Pump gas deal, Iím fine with 5 lbs, likely a Silber but BD or MTNTK are the other options Iíd consider. (Still need to research which one will keep best bottom for my tree riding).
Couple questions:
- am I at a mileage I should maybe just pass on the turbo idea? Or so long as I pop pistons in on a regular basis will it matter?
- what kind of mileage have you seen on turboíd Axys with decent reliability?
I have never owned a turbo sled but it seems gone are the days of unreliable turbo setups, from reading and talking around seems like pull and go turbos are here.
Thanks for any input.
__________________
"short, fat, and stupid is no way to go through life son..."
Rate this post: Yes | No
  #2
Old 03-15-2018, 12:50 AM
snoballssnoglory's Avatar
snoballssnoglory snoballssnoglory is online now
Currently: Not set.
snoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond repute
Default
I wouldnít invest in a turbo on a 3500 mile sled. My personal preference. Your gonna start having other issues even if the motor holds.
__________________
2016 Axys 155 Silber Hair Dryer
2014 Pro Climb
Smiles for Miles!
  #3
Old 03-15-2018, 05:50 AM
diamonddave's Avatar
diamonddave diamonddave is offline
Currently: <<In-House PolarisTechnician not as involved in the shop
diamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond repute
Default
Quote:
I have to agree. Unless you plan on tearing the sled down to bare tunnel by each individual component and go through it, Iíd pass.
Turboís need good sound powertrain components (entire engine, clutches, computer control systems, wiring integrity) just to name a few.
A little wear in each adds up at the track and too often when there is an issue, the turbo kit is unfairly blamed.
I really donít even run an NA sled pass 2,000-2,500 miles without a full complete tear down and nowadays as cheaply built as they are and as expensive as parts are, I have stopped doing that.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to diamonddave For This Useful Post:
mountainhorse (03-20-2018)
  #4
Old 03-15-2018, 06:11 AM
2XM3's Avatar
2XM3 2XM3 is offline
Currently: 2017 Axys 174 Turbo, 2016Axys 163
2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute
Default
You can get pretty good life from a turbo motor, figure around 500-1000 miles before a rebuild lmao in all seriousness I would not turbo a 3500 mile sled you are asking for problems. Best bet, new sled, good turbo system ride 1 maybe 2 years, sell, repeat process
__________________
2013 and 2014 National Superboat Champions
The Following 2 Users Say Thank You to 2XM3 For This Useful Post:
ggcustoms (03-15-2018), xrs2628 (03-25-2018)
  #5
Old 03-15-2018, 01:51 PM
revrider07 revrider07 is online now
Currently: 850 modder
revrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond repute
Default
Good compression good to go turbo it the issues are easily found answers for. IMO turbo makes the 800 pro motor more durable.
The Following User Says Thank You to revrider07 For This Useful Post:
Snowmow (03-15-2018)
  #6
Old 03-15-2018, 01:58 PM
JJ_0909 JJ_0909 is offline
Currently: Not set.
JJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond repute
Default
Depends your plans with the sled. If you are the "keep the sled until I die" type of guy, I think its fine to do it, assuming *everything* is in good shape. EG, motor mounts, clutching, relays, exhaust valves, crank runout etc.
If you are the "I sell my sled all the time" guys, then yeah, its money wasted.
The Following User Says Thank You to JJ_0909 For This Useful Post:
  #7
Old 03-15-2018, 02:06 PM
madmax's Avatar
madmax madmax is offline
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
Default
Quote:
Originally Posted by JJ_0909 View Post
Depends your plans with the sled. If you are the "keep the sled until I die" type of guy, I think its fine to do it, assuming *everything* is in good shape. EG, motor mounts, clutching, relays, exhaust valves etc.
Good advice
__________________
19í Alpha 800 turbo
18, MC 153 stock
18í axys 155 stock
17í Cat 800 snow pro 153 alpha skid
  #8
Old 03-15-2018, 02:21 PM
thump426er's Avatar
Currently: Not set.
Default
Thanks for the input!
Iím generally the leave it stock and upgrade sled every 3 years guy. But the Axys chassis fits my riding so well and Iím at the point where the cost isnít making as much sense to me to buy new, the cost of a turbo is pretty reasonable now, and Iíd like to step up the power game a bit. I guess ďa bitĒ would be a pipe and some easy mods really. The turbo question is more of a could I get away with a lot more riding with more maintenance to keep a turbo sled going for some more years. Either my 16 or a new 19 is going to stay with me for a longer time then I usually do is what Iím getting at, but want the power.
The smart choice I know is buy the 850 and run out the warranty.
__________________
  #9
Old 03-15-2018, 02:32 PM
Currently: Not set.
Default
Semi-unrelated, anyone looking for the best performance at lowest price, go buy a hold over 18. Turbo it. You'll be all in for less than the price of an 850, and run circles around it allllllllllllllllllllll day.
3 out of 3 members found this post helpful. Rate this post: Yes | No
  #10
Old 03-15-2018, 02:53 PM
Spaarky's Avatar
Spaarky Spaarky is online now
Currently: Moved Into Maximum Security Cell
Spaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond repute
  #11
Old 03-15-2018, 03:10 PM
Currently: Not set.
Click Here to Register
  #12
Old 03-15-2018, 03:54 PM
sumtinwong sumtinwong is online now
Currently: Not set.
Basic Member
sumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond repute
The Following User Says Thank You to sumtinwong For This Useful Post:
thump426er (03-16-2018)
  #13
Old 03-15-2018, 09:03 PM
ggcustoms's Avatar
ggcustoms ggcustoms is offline
Currently: dreaming of snowflakes
ggcustoms has a reputation beyond reputeggcustoms has a reputation beyond reputeggcustoms has a reputation beyond reputeggcustoms has a reputation beyond reputeggcustoms has a reputation beyond reputeggcustoms has a reputation beyond reputeggcustoms has a reputation beyond reputeggcustoms has a reputation beyond reputeggcustoms has a reputation beyond reputeggcustoms has a reputation beyond reputeggcustoms has a reputation beyond repute
  #14
Old 03-15-2018, 09:15 PM
Spaarky's Avatar
The Following User Says Thank You to Spaarky For This Useful Post:
  #15
Old 03-15-2018, 09:50 PM
MOABNUT MOABNUT is offline
Currently: Not set.
MOABNUT has a reputation beyond reputeMOABNUT has a reputation beyond reputeMOABNUT has a reputation beyond reputeMOABNUT has a reputation beyond reputeMOABNUT has a reputation beyond reputeMOABNUT has a reputation beyond reputeMOABNUT has a reputation beyond reputeMOABNUT has a reputation beyond reputeMOABNUT has a reputation beyond reputeMOABNUT has a reputation beyond reputeMOABNUT has a reputation beyond repute
The Following User Says Thank You to MOABNUT For This Useful Post:
  #16
Old 03-15-2018, 10:06 PM
LongHorn XC LongHorn XC is online now
Currently: Play Time is over, back to work
LongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond repute
The Following 3 Users Say Thank You to LongHorn XC For This Useful Post:
Nooby (03-31-2018), sumtinwong (03-15-2018), thump426er (03-20-2018)
  #17
Old 03-16-2018, 10:48 AM
Currently: Not set.
  #18
Old 03-19-2018, 08:16 PM
Ktmsx350f Ktmsx350f is offline
Currently: Not set.
Basic Member
Ktmsx350f has a reputation beyond reputeKtmsx350f has a reputation beyond reputeKtmsx350f has a reputation beyond reputeKtmsx350f has a reputation beyond reputeKtmsx350f has a reputation beyond reputeKtmsx350f has a reputation beyond reputeKtmsx350f has a reputation beyond reputeKtmsx350f has a reputation beyond reputeKtmsx350f has a reputation beyond reputeKtmsx350f has a reputation beyond reputeKtmsx350f has a reputation beyond repute
  #19
Old 03-20-2018, 07:12 AM
kylant kylant is offline
Currently: Getting ready
kylant has a reputation beyond reputekylant has a reputation beyond reputekylant has a reputation beyond reputekylant has a reputation beyond reputekylant has a reputation beyond reputekylant has a reputation beyond reputekylant has a reputation beyond reputekylant has a reputation beyond reputekylant has a reputation beyond reputekylant has a reputation beyond reputekylant has a reputation beyond repute
  #20
Old 03-20-2018, 07:43 AM
High Voltage's Avatar
High Voltage High Voltage is online now
Currently: Helena MT who wants to go sledding?
High Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond repute
  #21
Old 03-20-2018, 08:20 AM
Currently: Not set.
  #22
Old 03-20-2018, 02:38 PM
mountainhorse's Avatar
mountainhorse mountainhorse is online now
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
  #23
Old 03-20-2018, 02:46 PM
Currently: Not set.
  #24
Old 03-20-2018, 07:59 PM
Octanee Octanee is offline
Currently: Not set.
Octanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond repute
The Following 2 Users Say Thank You to Octanee For This Useful Post:
Snowman.PRO. (08-30-2018), XC500mod (04-02-2018)
  #25
Old 03-21-2018, 09:21 AM
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — High mileage 600 or low mileage/newer 550 fan? Thread Starter — 97exc Forum — Ski-Doo: REV Sleds Replies — 0 Last Post — 12-30-2011 06:36 PM
Thread — High Mileage M7 Thread Starter — pinko Forum — Arctic Cat: M Series Replies — 8 Last Post — 10-06-2010 03:30 AM
Thread — High Mileage vs Crank Thread Starter — KTG151 Forum — Polaris: EDGE Replies — 9 Last Post — 12-07-2009 09:36 PM
Thread — what is considered high mileage Thread Starter — alyce001 Forum — Polaris: EDGE Replies — 9 Last Post — 11-24-2009 01:51 AM
Thread — '08 XP High Mileage? Boondocking? Thread Starter — AaronBND Forum — Ski-Doo: XP Sleds Replies — 14 Last Post — 09-20-2009 11:04 AM
no new posts
