Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 02-28-2018, 09:58 AM
snopro75 snopro75 is offline
Currently: Sled is a pro...not me
Basic Member
snopro75 has a brilliant futuresnopro75 has a brilliant futuresnopro75 has a brilliant futuresnopro75 has a brilliant futuresnopro75 has a brilliant futuresnopro75 has a brilliant futuresnopro75 has a brilliant futuresnopro75 has a brilliant futuresnopro75 has a brilliant futuresnopro75 has a brilliant futuresnopro75 has a brilliant future
Default 11 m8 wont rev
Hey guys new guy here w 1st post. . Picked up a 2011 m8 (1700 miles)over the summer as a starter sled after my friend's got me hooked last winter. On our last trip out on 3 different occasions it wouldnt rev past 7700. Sounded exactly like a rev limiter. If I shut it off and restarted it would work fine for quite a while. The wrench icon on console came on steady w/o a code each time. I'm assuming there's a code that goes along with the wrench every time. Is there a way I can retrieve the code short of taking it to the dealer? Or does anyone know exactly what the prob is? I am very much mechanically inclined but electric is my admitted weak point.
Rate this post: Yes | No
  #2
Old 02-28-2018, 11:23 AM
jim jim is online now
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
Default
https://www-assets.arcticcat.com/con...d-Mountain.pdf
Codes are on page 9. The wrench light typically blinks a number of times to indicate the code. If constantly illuminated, I'm not sure what this means.
As for the rev, could be power valves not opening or you might need to adjust clutching.
The Following User Says Thank You to jim For This Useful Post:
hunterdon (03-09-2018)
  #3
Old 02-28-2018, 12:37 PM
Basic Member
Default
Thanks. I will ck valves and cables. Good to know that codes will flash on guage. I thought maybe i needed to jumper some wires/pins to get codes like my pu.
  #4
Old 03-01-2018, 08:39 PM
Skywest Skywest is offline
Currently: Not set.
Basic Member
Skywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond repute
Default
if I am not mistaken the wrench just means that the ecu is reading that something is out of limits. if you get a code it should be flashing "ECU" and then the indicating number at the same time. For example: a flashing "ECU 12" is failure in the ignition coils.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2006 m6 wont rev out Thread Starter — ilovepowder Forum — Arctic Cat: M Series Replies — 5 Last Post — 03-08-2013 08:15 PM
Thread — 2007 M8 wont rev Thread Starter — leadfoot33 Forum — Arctic Cat: M Series Replies — 3 Last Post — 01-12-2013 11:24 AM
Thread — 09 800rmk wont rev, acts like a rev limiter at around 7000 rpm Thread Starter — Wheel House Motorsports Forum — Polaris: IQ Replies — 14 Last Post — 12-27-2010 03:39 PM
Thread — Wont rev over 6500 Thread Starter — dancat Forum — Arctic Cat Replies — 9 Last Post — 02-12-2008 07:47 PM
Thread — 07 600 wont go into rev. Thread Starter — happylilcuss Forum — Polaris Replies — 3 Last Post — 01-07-2008 03:09 PM
no new posts
