Upgrade to Premium
Polaris: IQ 2005-Current, all models in the IQ and IQ Raw chassis
Reply
  #1
Old 02-28-2018, 07:41 AM
NorthwoodsHugh NorthwoodsHugh is offline
Currently: Not set.
Basic Member
NorthwoodsHugh is an unknown quantity at this point
Default 2007 iq 600 cfi very low compression.
bought a iq 600 with crank bearing out, bought a use crank out of 2010 rush 600 cfi. add a slp top end kit, new seals and gaskets. put a few 100 miles on it but my rpms come up short. 7750 or so kinda inconsistant. after changing cfi fuel filter, and testing sled. I did compression test. 60 on both sides.. tried on other sled 110.. WTH, well head could be loose i guess, crank could be wrong. bunch of other things as well.. Any help welcome.. Thanks
Rate this post: Yes | No
  #2
Old 02-28-2018, 01:57 PM
XCaSSAULT's Avatar
XCaSSAULT XCaSSAULT is offline
Currently: Go MN Wild!
XCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond repute
Default
Welcome to the forum��
I don’t know much about the slp stuff but I believe they have interchangeable combustion chambers in them. You’ll have to see what chambers are in there or maybe they aren’t on at all.
I think I’d try putting the stock head on, then do a compression test. I don’t think you’d wanna run it with stock head though cause I assume since u have the slp head on u also have the pipe, air box mod and fuel controller with specific map, that all wouldn’t play nice with stock head.
While u have the head off you’ll want to examine everything (pistons, cylinders etc) for any signs of failure.
Polaris made a bunch of different 600’s like carb or cfi, 2 or 4 injector models. I’d think the cranks would be the same but u could always check part numbers at Polarispartshouse.com
  #3
Old 02-28-2018, 05:10 PM
Currently: Not set.
Basic Member
Default
sorry I meant spi, no special heads or anything else
  #4
Old 03-01-2018, 09:06 AM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
Looking at the parts fiche for both engines the crankshafts are a different part number and even the pistons are a different part number. Kind of weird because the bore and stroke are the same for both engines. Either tear it down again for inspection or get hold of someone like Carls cycle or Indy Specialties to see if incompatibility is the problem.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2007 800R Low Compression After Full Rebuild Thread Starter — RTB Forum — Ski-Doo Replies — 23 Last Post — 05-02-2014 08:13 AM
Thread — 2007 M8 compression getting low? Thread Starter — M8Spenny Forum — Arctic Cat: M Series Replies — 4 Last Post — 01-05-2011 07:44 AM
Thread — 2007 600 compression Thread Starter — sledgreg Forum — Polaris: IQ Replies — 2 Last Post — 10-12-2010 06:07 AM
Thread — 2007 600 CFI compression Thread Starter — STICKDUDE Forum — Polaris: IQ Replies — 2 Last Post — 02-01-2010 08:36 PM
Thread — Compression on an 2007 600 HO SDI Thread Starter — KFD070 Forum — Ski-Doo Replies — 2 Last Post — 06-16-2009 10:30 AM
no new posts
