Upgrade to Premium
Reply
  #1
Old 02-25-2018, 05:21 PM
walker walker is offline
Currently: Not set.
walker has a reputation beyond reputewalker has a reputation beyond reputewalker has a reputation beyond reputewalker has a reputation beyond reputewalker has a reputation beyond reputewalker has a reputation beyond reputewalker has a reputation beyond reputewalker has a reputation beyond reputewalker has a reputation beyond reputewalker has a reputation beyond reputewalker has a reputation beyond repute
Default Broken handlebar on left side on 2013 Summit 800. Anyone seen this
Just bought the sled made it about a hundred feet down the trail and snap left side handlebar broke off where the hole is for the mountain bar. Is this a common thing
Click image for larger version
Rate this post: Yes | No
  #2
Old 02-25-2018, 08:23 PM
diggler's Avatar
diggler diggler is offline
Currently: moddin the garage
diggler has a reputation beyond reputediggler has a reputation beyond reputediggler has a reputation beyond reputediggler has a reputation beyond reputediggler has a reputation beyond reputediggler has a reputation beyond reputediggler has a reputation beyond reputediggler has a reputation beyond reputediggler has a reputation beyond reputediggler has a reputation beyond reputediggler has a reputation beyond repute
Default
yep i have seen that, quick note dont buy the same replacements, either get the X handlebars or CFR. Might as well throw ODI grips on it while your at it.
__________________
15' Summit T3 163
14' Summit X XM 154
11' HD Street Glide
The Following User Says Thank You to diggler For This Useful Post:
walker (02-26-2018)
  #3
Old 02-25-2018, 09:29 PM
Dessertdoo Dessertdoo is offline
Currently: Not set.
Basic Member
Dessertdoo is an unknown quantity at this point
Default
I had the same thing happen pretty common,like said above replace with the x the mountain strap raps around the bar instead of a hole through the bar
The Following User Says Thank You to Dessertdoo For This Useful Post:
walker (02-26-2018)
  #4
Old 02-25-2018, 10:36 PM
treeboy treeboy is offline
Currently: Not set.
Basic Member
treeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond repute
Default
Pretty common because of the way the mounted the mountain strap. Should have been a clamp not a bolt through the handle bars.
The Following User Says Thank You to treeboy For This Useful Post:
walker (02-26-2018)
  #5
Old 02-26-2018, 03:04 PM
bnorth bnorth is offline
Currently: Slednuck
Basic Member
bnorth has a reputation beyond reputebnorth has a reputation beyond reputebnorth has a reputation beyond reputebnorth has a reputation beyond reputebnorth has a reputation beyond reputebnorth has a reputation beyond reputebnorth has a reputation beyond reputebnorth has a reputation beyond reputebnorth has a reputation beyond reputebnorth has a reputation beyond reputebnorth has a reputation beyond repute
Default
They changed it in 2014 so the mountain strap clamps on and doesn't bolt through to eliminate that weak point.
1 out of 1 members found this post helpful. Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Wtf left haND side panel for summit xp, poss right as well Thread Starter — snowmanx Forum — WTB (Swapmeet) Replies — 2 Last Post — 03-23-2017 05:50 PM
Thread — Summit 1000 left side belly pan Thread Starter — jacmmaxwell Forum — WTB (Swapmeet) Replies — 0 Last Post — 09-18-2010 05:40 PM
Thread — Left side drive shaft cover/holder broken zirk Thread Starter — Stumper Forum — Polaris: 900 Replies — 6 Last Post — 11-16-2009 05:44 PM
Thread — Like new left side panel(black) Rev/summit Thread Starter — bigairpix Forum — Hoods/Windshields/Belly Pans (Swapmeet) Replies — 2 Last Post — 01-21-2008 04:35 PM
Thread — WTB. 02 summit left side trailing arm Thread Starter — Duddin Forum — Suspension/Shocks (Swapmeet) Replies — 0 Last Post — 12-11-2007 06:30 PM
