Upgrade to Premium
Ski-Doo: XP Sleds 2007.5-current, all models in the XP, XT and XR chassis
Reply
  #1
Old 02-19-2018, 10:55 PM
Chaseboka20 Chaseboka20 is offline
Currently: Not set.
Basic Member
Chaseboka20 is an unknown quantity at this point
Default 2008 xp clutch not engaging right
I put a new belt on my 800 xp and it’s over-Revving at low speed then like upshifts and takes off and runs good until I slow down to let it get within 15-20 mph then keeps doing it?
Rate this post: Yes | No
  #2
Old 02-20-2018, 12:28 PM
cubby's Avatar
cubby cubby is online now
Currently: Riding Atv's till the snow comes back
cubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond repute
Default
What belt are you running, is it OEM if so what's the number of the belt? Is the deflection setup right? What clicker are you running on and what elevation are you at? Need to know more info so we can help you out.
__________________
2016 T3 154"
2007 XRS 800 151" engine built by SHR
2013 Polaris 850xp
2015 Polaris 1000xp
2016 Polaris 170 RZR
Hold it pinned till you feel bad
  #3
Old 03-12-2018, 09:45 PM
shockman shockman is offline
Currently: Not set.
Basic Member
shockman has a reputation beyond reputeshockman has a reputation beyond reputeshockman has a reputation beyond reputeshockman has a reputation beyond reputeshockman has a reputation beyond reputeshockman has a reputation beyond reputeshockman has a reputation beyond reputeshockman has a reputation beyond reputeshockman has a reputation beyond reputeshockman has a reputation beyond reputeshockman has a reputation beyond repute
Default
sounds to me like ramps have a notch worn in them, have you looked at primary? these were horrible for wear and haven't seen one with 2000mi that wasn't completely worn out
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #4
Old 04-10-2018, 07:12 PM
FarmboyAB FarmboyAB is offline
Currently: Not set.
Basic Member
FarmboyAB is an unknown quantity at this point
Garage
Default
Quote:
X2. Had the same problem this last January. I would definitely look into this.
  #5
Old 04-13-2018, 11:24 AM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
Set belt deflection as tight as possible without creeping or squealing.
Then check out the primary for wear. They generally need a rebuild kit at 1500-2000 mountain miles, as well as the divot in the ramps as already mentioned. The divot develops when there is excessive wear in other parts like bushings, slider buttons etc...
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — clutch engaging too soon? Thread Starter — spidermonkey Forum — Ski-Doo: REV Sleds Replies — 7 Last Post — 12-18-2013 05:02 PM
Thread — clutch engaging too low? Thread Starter — ddog96mn Forum — Polaris: GEN 1 and older Replies — 2 Last Post — 10-21-2011 07:45 PM
Thread — 07 m8 clutch engaging hard Thread Starter — mulestar Forum — Arctic Cat: M Series Replies — 6 Last Post — 01-11-2011 05:22 PM
Thread — clutch engaging Thread Starter — motocross_48 Forum — Arctic Cat: M Series Replies — 1 Last Post — 12-16-2009 02:58 PM
Thread — Clutch engaging at 5K RPM Thread Starter — seth25 Forum — Arctic Cat Replies — 2 Last Post — 03-04-2008 02:26 PM
no new posts
