Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 01-26-2018, 10:07 AM
BD-Xtreme's Avatar
BD-Xtreme BD-Xtreme is offline
Currently: Not set.
BD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond repute
Default PROMAX INDUCTION SYSTEM KIT FOR 2012-2017 PROCLIMB/PROCROSS
Now you can update your 2012-2017 model Arctic Cat 800 or 600 with our ProMax Intake and Headlight Delete!
8 lbs lighter than stock! Also adds 2-3 hp over stock when we tested on the dyno!
The windshield/dash is all one piece with added air intake induction for deep snow.
You get the lower intake hood plenum to replace your stock one. The new intake plenum has air intake vents on the side.
The third component is the mid intake plenum that directs the air flow from the dash down to the throttle bodies.
We then supply you with some Frogskin air intake vents that go on the hood under the upper side hood covers, and two more hidden above the shock area on each side. There are two more Frogskin vents that cover the two intake holes by the dash.
With this kit it allows the motor to get cold air from the front, sides, and up by the dash in deep snow.
A great way to drop a lot of weight, gain some power and has a cool look for your sled too!
We do offer 6" LED Lights that can be added on top of the dash too, or better yet, check out our ProVision bumpers with built in LED lights!!
http://www.bd-xtreme.com/index.php?i...roller=product
Click image for larger version
ID:	292132   Click image for larger version
Name:	20071 promax hood.jpg
ID:	292133   Click image for larger version
ID:	292135   Click image for larger version
ID:	292136   Click image for larger version
ID:	292138   Click image for larger version
Rate this post: Yes | No
  #2
Old 01-26-2018, 02:35 PM
Frostbite's Avatar
Frostbite Frostbite is offline
Currently: Dreaming of riding in deep, deep powder!
Frostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond repute
Default
Nice stuff guys! I am most impressed by the 8 lbs. of weight savings (up high on the sled) for $249.00. That alone might be enough reason to buy the kit.
What results did your field testing yield?
How many hours and how indepth of a job is it to add this kit?
Were there any snow ingestion or bogging issues encountered?
__________________
The Original Frostbite
  #3
Old 01-27-2018, 01:41 AM
Suzzy-Q Suzzy-Q is offline
Currently: Not set.
Suzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond repute
Default
Is this what comes with the accender hood/side panel kit but without the panels and belly pan and hood pieces?
__________________
2017 mountain cat 153; SSI stainless can/y-pipe, SSI pipe mod, pro-cool head, boysen rage cages, Mohawks
2012 sp, 38" front, 162x3, slp stage 2,PCV with timing, mountain fit hood, C3 Belt Drive 2.52, WRP seat, BDX boards(SOLD)
  #4
Old 02-02-2018, 11:24 AM
BD-Xtreme's Avatar
Currently: Not set.
Default
We ran these kits on our sleds all last season. 600, 800 and 950's. They really work well and you can actually feel in improvement in throttle response with them on since the motor is getting cooler air all of time. We did dyno test in on a 8000 and 950 and the promax hood always made a couple more hp over the stock hood.
They work excellent in deep snow especially since if the nose is buried, which it will still suck air from the dash.
  #5
BD-Xtreme's Avatar
Currently: Not set.
Default
Quote:
Yes it is the exact same pieces that is in the ascender hood kit.
  #6
Old 02-11-2018, 02:45 PM
Frostbite's Avatar
Default
I am very tempted to try one of these kits and would love to save 8 pounds up high on my sled but, I don't want to ruin the look of my sled too much.
I don't imagine a stock short windshield would be able to be installed on this setup?
__________________
  #7
Old 02-12-2018, 09:09 PM
cadeskii cadeskii is offline
Currently: Not set.
cadeskii has a reputation beyond reputecadeskii has a reputation beyond reputecadeskii has a reputation beyond reputecadeskii has a reputation beyond reputecadeskii has a reputation beyond reputecadeskii has a reputation beyond reputecadeskii has a reputation beyond reputecadeskii has a reputation beyond reputecadeskii has a reputation beyond reputecadeskii has a reputation beyond reputecadeskii has a reputation beyond repute
Default
I am wondering about this too. I want to keep my windshield on for looks. Also wondering if the setup would be strong enough not to break when the sled is rolled
The Following User Says Thank You to cadeskii For This Useful Post:
Frostbite (02-13-2018)
  #8
Old 03-05-2018, 02:55 PM
Thunder101 Thunder101 is offline
Currently: making room in the garage :)
Thunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond repute
Default
Any reviews on this ?
Fawk do I hate my hood !
  #9
Old 03-10-2018, 12:39 PM
BD-Xtreme's Avatar
Currently: Not set.
Default
Basically what we did is mimic a similar look to the stock short windshield with our new windshield/dash pad. We just incorporated the windshield and dash into one.
The Following User Says Thank You to BD-Xtreme For This Useful Post:
Bengalfan (03-24-2018)
  #10
Old 04-05-2018, 01:01 PM
BD-Xtreme's Avatar
Currently: Not set.
  #11
Old 08-19-2018, 05:45 PM
irydcat's Avatar
irydcat irydcat is offline
Currently: Independent Rider
irydcat has a reputation beyond reputeirydcat has a reputation beyond reputeirydcat has a reputation beyond reputeirydcat has a reputation beyond reputeirydcat has a reputation beyond reputeirydcat has a reputation beyond reputeirydcat has a reputation beyond reputeirydcat has a reputation beyond reputeirydcat has a reputation beyond reputeirydcat has a reputation beyond reputeirydcat has a reputation beyond repute
Click Here to Register
  #12
Old 08-27-2018, 03:30 PM
BD-Xtreme's Avatar
Currently: Not set.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — BDX PROMAX INDUCTION COLD AIR INTAKE Thread Starter — Speed Shop Inc. Forum — 2018 Ascender Replies — 23 Last Post — 03-10-2017 11:03 AM
Thread — PROMAX INDUCTION HOOD FOR 2018 M8000DSI Thread Starter — Speed Shop Inc. Forum — Black Diamond/Speed Shop Inc Replies — 0 Last Post — 02-23-2017 02:45 PM
Thread — BDX ProMax Induction Hood and Intake Thread Starter — Speed Shop Inc. Forum — Black Diamond/Speed Shop Inc Replies — 0 Last Post — 02-23-2017 10:59 AM
Thread — 2012-2017 Proclimb Boondocker Intercooled Turbo Kit Thread Starter — shawkins Forum — Turbos/Superchargers (Swapmeet) Replies — 0 Last Post — 03-28-2016 07:57 AM
Thread — BIKEMAN can for 2012-2012 Arctic Cat Procross Proclimb 800 Thread Starter — 98woody Forum — Pipes/Cans (Swapmeet) Replies — 6 Last Post — 09-09-2012 04:38 AM
no new posts
