Upgrade to Premium
Trucks and Trailers Towing and hauling your sleds
Reply
  #1
Old 01-04-2018, 12:08 AM
bowtieboy bowtieboy is offline
Currently: Yeah Its gotst a Hemi
Basic Member
bowtieboy is an unknown quantity at this point
Default Sled deck build
Decided to build a sled deck, using a flat deck I had built for a truck I used to have. As it sits right now it’s 80” wide/8’ long and has 1” fur decking. Which I’m considering replacing with 1/2” to save weight.
Stripped it down yesterday, built some legs for it today. Left enough room and height for the ramp to slide in on the bottom side of the deck.
I’m planning on pinning it into the fifth wheel rails in my box as well as turnbuckles.
I have to finish welding the legs, add some gussets and as well as remove and rebuild the headache rack. Also I plan to make sides that slide/pin in to make it 8’ wide.
Click image for larger version
ID:	290761   Click image for larger version
ID:	290762   Click image for larger version
ID:	290764   Click image for larger version
Rate this post: Yes | No
The Following User Says Thank You to bowtieboy For This Useful Post:
GreenState (01-04-2018)
  #2
Old 01-06-2018, 12:31 PM
Basic Member
Default
Doesn’t look like I got lots done, but I did a fair bit. Welded everything up, added some gussets, tie down tabs on the deck.
Tied the legs in to each other, than made 2 pieces of tube pin into the rails.
Edit: not sure why my phone is putting random pics sideways.
ID:	290950   Click image for larger version
  #3
Old 01-06-2018, 08:53 PM
Pro-8250's Avatar
Pro-8250 Pro-8250 is offline
Currently: Have fun while you can
Pro-8250 has a reputation beyond reputePro-8250 has a reputation beyond reputePro-8250 has a reputation beyond reputePro-8250 has a reputation beyond reputePro-8250 has a reputation beyond reputePro-8250 has a reputation beyond reputePro-8250 has a reputation beyond reputePro-8250 has a reputation beyond reputePro-8250 has a reputation beyond reputePro-8250 has a reputation beyond reputePro-8250 has a reputation beyond repute
Default
Take your pictures horizontal with your phone. See if that helps. $.02
__________________
They make take me but never take us all.
  #4
Old 01-07-2018, 07:42 PM
Basic Member
Default
Must be the forum itself. Another forum I’m on never have this problem.
Posted a pic taken horizontal and it uploaded upside down.
This pic was taken vertical.
Anyways, got the head ache rack made. It came out quite nice I think.
  #5
Old 01-13-2018, 01:12 PM
Basic Member
Default
Got a fair bit done.
Got some 1 7/8” pipe on the back for the ramp to hook into, as well a solid bar to extend out another foot or so.
Plasma’d some holes for the sides, got them so the pin in and slide out to 8’ wide. Still need to do a little reinforcing on them.
Got buddy at work to plasma me ski guards and some for the ramp as well.
ID:	291405   Click image for larger version
ID:	291406   Click image for larger version
ID:	291408   Click image for larger version
ID:	291409   Click image for larger version
  #6
Old 02-11-2018, 11:39 PM
Basic Member
Default
Finished the deck up a couple weeks back. Built an 8’ ramp that slides in. Used 3/8” treated plywood for decking. Have used it a couple times already.
ID:	292918   Click image for larger version
ID:	292919   Click image for larger version
  #7
Old 02-12-2018, 07:22 AM
DangerousDave's Avatar
DangerousDave DangerousDave is offline
Currently: Building a new sled deck...
DangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond repute
Default
Looks good, are there extensions on the sides of the back rail for the ramp to hook to for loading the second Sled? Any ski slides? I used strips of old bed liner for the last couple I built.
  #8
Old 02-12-2018, 10:17 AM
Basic Member
Default
I used some 1.5” round bar that slides into the tubing to extend the ramp mount over. Worked out quite well actually.
Haven’t bothered with slides yet. If I gets old of a bed liner I may do something. I did get ahold of some superglides for the ramp though. They work pretty slick.
  #9
Old 02-12-2018, 10:21 AM
Basic Member
Default
Guess I did have a pic of it.
  #10
Old 02-22-2018, 07:23 AM
absentgenius absentgenius is offline
Currently: Not set.
Basic Member
absentgenius has a reputation beyond reputeabsentgenius has a reputation beyond reputeabsentgenius has a reputation beyond reputeabsentgenius has a reputation beyond reputeabsentgenius has a reputation beyond reputeabsentgenius has a reputation beyond reputeabsentgenius has a reputation beyond reputeabsentgenius has a reputation beyond reputeabsentgenius has a reputation beyond reputeabsentgenius has a reputation beyond reputeabsentgenius has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Alu sled deck build Thread Starter — spark'd Forum — Trucks and Trailers Replies — 20 Last Post — 03-30-2014 11:25 AM
Thread — looking to build a sled deck Thread Starter — camaroz28 Forum — Trucks and Trailers Replies — 1 Last Post — 11-25-2013 10:26 AM
Thread — Sled deck build Thread Starter — Rixster Forum — Trucks and Trailers Replies — 42 Last Post — 01-12-2011 06:32 PM
Thread — sled deck build Thread Starter — 13below0 Forum — Trucks and Trailers Replies — 2 Last Post — 01-17-2010 09:00 PM
Thread — Anybody build their own sled deck? Thread Starter — luv2sledmt Forum — Trucks and Trailers Replies — 16 Last Post — 07-29-2009 01:07 PM
no new posts
