Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 12-30-2017, 11:02 AM
Chadly's Avatar
Chadly Chadly is online now
Currently: Not set.
Chadly has disabled reputation
Default Engine Faults with MPI kit...
Every now and then I'm getting the Over Rev followed instantly by the knock message on the display on my sled. I am resetting the max rpm gauge everytime and the highest RPM I have seen is 7900 rpm so there is no way it's over revving per the gauge. Running straight 100 octane so knock seems unrealistic as well. Wondering if an over fueling issue would cause these faults because it sure seems like its running rich...
Rate this post: Yes | No
  #2
Old 12-31-2017, 08:18 AM
snoblind04's Avatar
snoblind04 snoblind04 is online now
Currently: having a blast on my mpi turbo
snoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond repute
Default
I've been running with about a gallon of 110 per tank in mine. No issues yet but I only have two rides so far.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 01-11-2018, 11:41 PM
madmax's Avatar
madmax madmax is online now
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
Default
Quote:
How often you getting the knock code?
  #4
Old 01-12-2018, 07:32 AM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
Over rev can also be triggered when the rate of RPM increase is too quick. loading the primary quicker/harder takes care of that.
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to winter brew For This Useful Post:
mountainhorse (01-13-2018)
  #5
Old 01-12-2018, 03:29 PM
ghost rider ghost rider is offline
Currently: videos
ghost rider has a reputation beyond reputeghost rider has a reputation beyond reputeghost rider has a reputation beyond reputeghost rider has a reputation beyond reputeghost rider has a reputation beyond reputeghost rider has a reputation beyond reputeghost rider has a reputation beyond reputeghost rider has a reputation beyond reputeghost rider has a reputation beyond reputeghost rider has a reputation beyond reputeghost rider has a reputation beyond repute
Default Mpi
Quote:
As stated above is probably what's happening. Happened to me last year a few times when the track came unloaded. I started last year with ski doo clutch components(only thing out there) and even tho I loaded it heavier with heavier ramp and heavier spacers it happened occasionally. I run 2 gallons of Av per tank and good non ethanol 93. This year I switched to sled head racing ramps(full clutch kit)loaded all the way and number 3 spacer weight, clicker 2 at 7-10,000 ft. I'm running around 8-8100 rpm at all elevations and conditions, up 4-5mph track speed to 52mph from 47ish. No blown belts and cooler clutch temps. Im at over 1000 miles on kit and in my opinion the best setup I've rode or ride with. Everyone can talk about how there turbo kit has ecu programmed or run a piggy back controller etc but if you don't have your clutching dialed it's all for not. Then you have the blend of fuel to deal with as well. To much race or Av and it feels lazy and rich and response goes to crap(once again doesn't matter which kit you have whether piggy back or programmed ecu) to little and you burn it down. I have no affiliation with any product manufacturer and have ran all there kits in the past. Loving my mpi 850
  #6
Old 01-12-2018, 10:14 PM
fredw fredw is offline
Currently: 850 blown up before Breakin over
Basic Member
fredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond repute
Default
Another idea to slow burn rate of fuel is add a degree or two of timing, I have just done that and it has picked up on response
  #7
Old 01-13-2018, 09:54 AM
pepperhouse pepperhouse is offline
Currently: Not set.
pepperhouse has a reputation beyond reputepepperhouse has a reputation beyond reputepepperhouse has a reputation beyond reputepepperhouse has a reputation beyond reputepepperhouse has a reputation beyond reputepepperhouse has a reputation beyond reputepepperhouse has a reputation beyond reputepepperhouse has a reputation beyond reputepepperhouse has a reputation beyond reputepepperhouse has a reputation beyond reputepepperhouse has a reputation beyond repute
Default
Quote:
Happy to hear your mpi kit is working for you, tried to go that way but got tired of waiting and jumped on a silber kit.
When you say fully loaded with shr clutch kit does that mean your running the 5gram tungsten and 3gram set screw, 8gram total tip weight?
Which pivot bolt are you using?
The stock one or the 4 gram one in kit
Anyone on here have a weight for stock pivot bolt?
  #8
Old 01-13-2018, 08:52 PM
snoblind04's Avatar
Default
I just weighted my stock bolt at 15.4 grams last years was about 17 grams.
I've got over 250 miles on my MPI turbo and it has run great, no codes or anything. I've run some pretty tuff snow and it has not missed a beat. Very happy so far.
I also switched to straight pump gas and I think it runs better than
The Following 2 Users Say Thank You to snoblind04 For This Useful Post:
fredw (01-13-2018), pepperhouse (01-14-2018)
  #9
Old 01-21-2018, 04:25 PM
rmk all the way rmk all the way is online now
Currently: Boost in progress!
rmk all the way has a reputation beyond reputermk all the way has a reputation beyond reputermk all the way has a reputation beyond reputermk all the way has a reputation beyond reputermk all the way has a reputation beyond reputermk all the way has a reputation beyond reputermk all the way has a reputation beyond reputermk all the way has a reputation beyond reputermk all the way has a reputation beyond reputermk all the way has a reputation beyond reputermk all the way has a reputation beyond repute
I know my 850 absolutely hates having more then about 25 percent av gas and sounds like it’s loading up really bad on the bottom end
  #10
Old 01-22-2018, 08:16 AM
Marcusx200 Marcusx200 is offline
Currently: Not set.
Basic Member
Marcusx200 is an unknown quantity at this point
  #11
Old 01-22-2018, 09:46 AM
Basic Member
Click Here to Register
  #12
Old 01-22-2018, 09:59 AM
Currently: Not set.
Basic Member
  #13
Old 01-23-2018, 05:15 PM
madmax's Avatar
Currently: Not set.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Stage 1 upgrade kit for MPI Yamaha 180 kit Thread Starter — Matt@MPI Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 26 Last Post — 12-20-2013 11:04 AM
Thread — 1160 Engine tech/1220 CMX 8/900 engine kit for sale Thread Starter — shaun897 Forum — Engine/Engine Parts (Swapmeet) Replies — 2 Last Post — 12-01-2012 10:21 AM
Thread — MPI super charger kit for vector for SALE (complete kit) Thread Starter — turbovector3 Forum — Turbos/Superchargers (Swapmeet) Replies — 0 Last Post — 11-15-2012 12:16 AM
Thread — MM MPI transfer kit?? Thread Starter — thierracing Forum — Yamaha: 2-stroke Replies — 13 Last Post — 11-02-2011 11:20 PM
Thread — My New MPI 180 Kit Thread Starter — stuck a lot Forum — Yamaha: 4-Stroke Replies — 3 Last Post — 12-13-2010 04:52 AM
no new posts
