Upgrade to Premium
Yamaha: 2-stroke Includes all Yamaha 2-strokes, Viper, Mountain Max, etc
Reply
  #1
Old 11-06-2017, 03:06 PM
clutchman clutchman is offline
Currently: Not set.
Basic Member
clutchman is an unknown quantity at this point
Default Install Electric Start on Phazer II
So I could use your opinion. How difficult is it so install electric start system on a non electric start phazer II 1992. I have a donor machine 1985 phazer so I would think it is pretty much plug and play with exception of ring gear on flywheel and installing starter.
What has been your experience? Any advice? It is for my daughter's starter sled.
Thanks in advance.
Rate this post: Yes | No
  #2
Old 11-11-2017, 10:15 AM
Givemeaboost's Avatar
Givemeaboost Givemeaboost is offline
Currently: Not set.
Givemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond repute
Default
I'm not familiar with the phazer but have done a couple of 700 mountaln maxes. I would think that they would be about the same.You'll need to pull the exhaust to mount the starter and a clutch puller to get the clutches off to switch the ring gear. Make sure to loctite the bolts on the ring gear. The ignition switch should have a start position built into it. I put electric start on a 01mm off my 97 that I sold and it works great.
Ken..........
__________________
03 rx1 mtn with homebuilt turbo , 159 finger track , Rev tank and seat. 01 Mountain Max
  #3
Old 01-04-2018, 07:15 PM
tinkerjohnson tinkerjohnson is offline
Currently: Tinker till I die
tinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond repute
Default E start install
I did it on my 1991 and I had to replace the complete harness from the battery to up in behind the headlight. Plugs are different and key switch aswell.
Reply
Bookmarks
Tags
electric, phazer, start
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — 15 t3 electric start install Thread Starter — Turblue Forum — Ski-Doo: XM Sleds Replies — 3 Last Post — 04-01-2016 02:38 PM
Thread — Phazer electric start Thread Starter — thumper450 Forum — Yamaha: 2-stroke Replies — 5 Last Post — 01-21-2016 08:29 PM
Thread — XP electric start Install Thread Starter — xteam Forum — Ski-Doo: XP Sleds Replies — 7 Last Post — 03-02-2011 09:24 PM
Thread — Electric start for 04 REV 800-anyone install? Thread Starter — BackCountryBob Forum — Ski-Doo: REV Sleds Replies — 3 Last Post — 02-24-2011 10:39 AM
Thread — electric start install help Thread Starter — xteam Forum — Ski-Doo: XP Sleds Replies — 2 Last Post — 10-25-2010 12:16 AM
no new posts
