Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 09-30-2017, 08:04 PM
Batwolf Batwolf is offline
Currently: Not set.
Batwolf is an unknown quantity at this point
Default PERC light always on
Hey fellas, new to the forum, and Polaris.
Picked up a 2005 switchback turned RMK near the end of last season. The ole 800 Liberty has 3400 miles on it, and basically got the full monty most of you are already familiar with at 2100. Anyway, getting to my issue, my PERC light is on all the time. I've had the sled out for three rides since I've owned it and reverse works well and exactly as it should aside from the light. Wiring looks good and the switch seems good also. I'm at least familiar enough with what the stock bars and switch set up would've been, and it's clear a RMK pro PERC switch in use. That said I figure the light has something to do with how the new PERC switch works with the older electronics of this model. Has anyone seen this before or have any insight on what else I should look at? Suppose it could be a difference in resistance loads from the old switch to the new? I do not have a wiring diagram to look at the signaling..
Click image for larger version
ID:	286155   Click image for larger version
Rate this post: Yes | No
  #2
Old 10-04-2017, 08:10 PM
Currently: Not set.
Default
Ideas anyone?
  #3
Old 10-05-2017, 11:10 AM
retiredpop retiredpop is online now
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
The stock switch makes a momentary contact closure when pushed to trigger the CDI and when released the contacts open. Does your new switch close the contact when pushed or does it open the contact when pushed? If it is a contact closure like the original then your problem lies elsewhere.
I have attached the wiring diagram for your sled. You will see the reverse light is turned on by a ground on the white lead from pin 9 of the CDI. The reverse switch puts a momentary ground on the grey lead on pin 22 of the CDI when pushed.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to retiredpop For This Useful Post:
Snow Duck (10-10-2017)
  #4
Old 10-05-2017, 10:14 PM
Currently: Not set.
Default
Excellent information- thank you!
I'll check a few thing out this weekend and see what I find. I'm willing to put money on it being related to this.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Did a head light delete. On my 16 axys 800 noes perc not working Thread Starter — walker Forum — Polaris: AXYS Replies — 6 Last Post — 03-12-2017 05:03 PM
Thread — 2008 XP800 summit x-shows shutdown/beeps/temp light/oil light Thread Starter — Snoghost Forum — Ski-Doo: XP Sleds Replies — 0 Last Post — 04-19-2016 02:28 PM
Thread — Temp light and check engine light in deep pow? Thread Starter — Blk88GT Forum — Ski-Doo: XM Sleds Replies — 16 Last Post — 02-24-2014 06:02 PM
Thread — 03 Polaris 800 non PERC motor in 04 chasis with PERC CDI? Thread Starter — go high fast Forum — Polaris: EDGE Replies — 12 Last Post — 08-31-2011 11:41 AM
Thread — Perc??? Thread Starter — winter Forum — Polaris Replies — 10 Last Post — 11-11-2008 07:24 PM
no new posts
