Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 08-26-2017, 10:44 AM
TransDoc TransDoc is offline
Currently: Working to ride...
Basic Member
TransDoc is an unknown quantity at this point
Default 2013 Pro RMK 800 Basic Engine Mods
Hi all. New to the forum here.
I just bought a bone stock 2013 Pro RMK 800. I want to do a few basic mods to tailor it to my style and preferences (plus, I can't leave anything alone...).
Engine mods planned are pretty basic. I'm planning on a fix kit (not sure which package...open to suggestions), a set of MDS 13.1:1 heads, and a SPI carbon fiber can. The sled only has about 600 miles on it, so I'm not super worried about the top end just yet, but I will probably go ahead and "kit" it and do the mods before the snow flies.
As far as the rest of the sled, there's a ton of good info on here, but I was hoping some first-hand suggestions and recommendations. I ride in NE Washington/North Idaho/NE Oregon neck of the woods, roughly 2200' at the absolute minimum (home), but mostly from, say, 4-7K most of the time, but up to 8-9K at times. I prefer boondocking and tree riding to straight-line hillclimbing, but do quite a bit of both.
Thanks for the help, and great forum!
Rate this post: Yes | No
  #2
Old 09-03-2017, 11:29 AM
diamonddave's Avatar
diamonddave diamonddave is offline
Currently: <<In-House PolarisTechnician not as involved in the shop
diamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond repute
Default
A Transmission Guy eh? I retired early from the industry after 22 years.
Go with the Fix Kit from MTNTK. Do not waste your time with anything else. I've installed about 25 of these kits with that same head and other's and they work great for our riding altitude, area's. They run way better than a stock set.
I do recommend having the injectors flow tested while you're out. Dr. Injector or Witch Hunter. Injector placement in these motors lends to incredible build up of carbon deposits prematurely. And '13's are the leanest map of all Pro's.
I recommend running the stock can. They're only 12lbs and run well.
IndyDan has a new honing procedure that looks very inviting. He says either use this or use nothing. Ring wear is an issue with this motor.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 09-05-2017, 10:50 PM
Basic Member
Default
Thanks for the advice! Like I said, I've been out of the game for quite a while, and I appreciate it.
Yes, I've been building transmissions for 30 years or so now. But mostly Dodge and Ford diesel automatics these days. They're my real bread and butter builds...hundreds of them. It's a living...!
Is it worth the extra money to get the lightweight piston Fix Kit? A hundred extra bucks. Worth it...?
  #4
Old 10-08-2017, 10:21 PM
peaceofwork peaceofwork is offline
Currently: Internet Rmkpro 800apprentiship
Basic Member
peaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond repute
Default
Dave do you have a link to those injector places? Or do Polaris dealers do testing and servicing on injectors .
  #5
Old 10-08-2017, 10:35 PM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
the other two mountain manufactures don't require you to add a "fix kit" to make their sleds run as advertised. so why would you take a know flawed setup over a proven other?
  #6
Old 10-10-2017, 06:13 PM
tuneman's Avatar
tuneman tuneman is online now
Currently: is a long track addict
tuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond repute
Default
Quote:
It's not as much of a flaw as the internet let's on. In fact, I've seen significantly more broken down Doos and Cats out west than Poo. And, where I ride, there are significantly more Polaris than the others. That's my personal experience, anyway. Not what I read on the internet...
__________________
-- Never Let Your Equipment Hold You Back --
  #7
Old 10-10-2017, 07:36 PM
Currently: Not set.
Garage
Default
Quote:
glad you make it out west a few times poor bastage.
When i ride the great lakes i see more broken down poos than cats and doos......LMFAO.
a few of the fix kits are using cat HO pistons to fix it. JFYI. I have installed a few...
  #8
Old 10-11-2017, 12:26 AM
LoudHandle LoudHandle is offline
Currently: I'd rather snowshoe than be caught on a SKIDOO! I'm not feminine / gay enough to ride SkiDoo either.
LoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond repute
Default
It's far easier to fix an engine (If one feels the need?) than fix all the chassis flaws of the other three manufactures.
__________________
ALASKA
  #9
Old 10-11-2017, 08:28 PM
Default
I do use the kit with the lighter pistons
Mountainhorse used to have a link for Witchunter. I just take mine into Dr. Injector as they are local.
Polaris does not have this ability.
Found there's.
http://www.witchhunter.com/
The Following User Says Thank You to diamonddave For This Useful Post:
peaceofwork (10-13-2017)
  #10
Old 10-19-2017, 11:16 AM
Basic Member
  #11
Old 02-02-2018, 12:52 AM
wildcard28's Avatar
wildcard28 wildcard28 is online now
Currently: Thinkin Snow! Bought APro Rmk Love this Sled
wildcard28 has a reputation beyond reputewildcard28 has a reputation beyond reputewildcard28 has a reputation beyond reputewildcard28 has a reputation beyond reputewildcard28 has a reputation beyond reputewildcard28 has a reputation beyond reputewildcard28 has a reputation beyond reputewildcard28 has a reputation beyond reputewildcard28 has a reputation beyond reputewildcard28 has a reputation beyond reputewildcard28 has a reputation beyond repute
Garage
Click Here to Register
  #12
Old 08-30-2018, 08:55 AM
Basic Member
  #13
Old 08-30-2018, 09:16 AM
Murph's Avatar
Murph Murph is online now
Currently: Back in the mountains
Murph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond repute
  #14
Old 08-31-2018, 09:03 AM
Basic Member
  #15
Old 08-31-2018, 02:34 PM
SayatodaU.P.eh? SayatodaU.P.eh? is offline
Currently: Waiting for snow...
SayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond repute
  #16
Old 08-31-2018, 07:40 PM
  #17
Old 09-05-2018, 10:56 AM
gtwitch gtwitch is online now
Currently: Not set.
gtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond repute
  #18
Old 09-06-2018, 05:43 AM
simnil simnil is offline
Currently: Not set.
Basic Member
simnil has a reputation beyond reputesimnil has a reputation beyond reputesimnil has a reputation beyond reputesimnil has a reputation beyond reputesimnil has a reputation beyond reputesimnil has a reputation beyond reputesimnil has a reputation beyond reputesimnil has a reputation beyond reputesimnil has a reputation beyond reputesimnil has a reputation beyond reputesimnil has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2013 Rmk Pro 800 engine. 1377 miles. Complete and runs great! Thread Starter — t30mg Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 04-24-2017 10:51 PM
Thread — 2013 polaris rmk 800 pro engine Thread Starter — keithm907 Forum — Engine/Engine Parts (Swapmeet) Replies — 1 Last Post — 08-05-2016 05:08 AM
Thread — 2013 pro rmk a arm mods Thread Starter — jonny3tears Forum — Polaris: Pro-Ride Replies — 1 Last Post — 01-07-2015 10:51 AM
Thread — 2013 Pro RMK Engine BRAND NEW Thread Starter — Devilmanak Forum — Engine/Engine Parts (Swapmeet) Replies — 2 Last Post — 03-03-2013 03:32 AM
Thread — 2003 Polaris RMK 800 engine with SLP Performance Edition mods Thread Starter — Sundance Kid Forum — Engine/Engine Parts (Swapmeet) Replies — 6 Last Post — 10-05-2012 10:29 PM
