Upgrade to Premium
Yamaha: Boosted Sleds (Turbo or Supercharged) Turbo discussion for Yamaha aftermarket Turbo or Super Charged sleds.
Reply
  #1
Old 03-05-2017, 09:59 PM
RMKing1 RMKing1 is offline
Currently: Not set.
Basic Member
RMKing1 has a brilliant futureRMKing1 has a brilliant futureRMKing1 has a brilliant futureRMKing1 has a brilliant futureRMKing1 has a brilliant futureRMKing1 has a brilliant futureRMKing1 has a brilliant futureRMKing1 has a brilliant futureRMKing1 has a brilliant futureRMKing1 has a brilliant futureRMKing1 has a brilliant future
Default 190 MPI Viper secondary spring setup?
Hey guys my 15' Viper has all the MPI recommended Yamaha clutch parts in it including the double white secondary spring, but it is currently set at 3 & 1 not the 6 & 1 MPI is recommending, I have no problem making RPM and I ride a bit lower 7500' tops then what they show in their chart 8-10,000' for that setting. Increasing spring tension to the #6 should improve back shift which is a little lazy on it and make it hold lower gear longer and help to fully close the secondary and return the top of the belt just above the sheave, which it currently isn't doing as it will sit 3/16" below the sheave when returning to idle on a stand (I shimmed the three bolts with two washers each on the back of the clutch and my belt sit's right at a 1/16 to an 1/8 th above the sheaves with the clutch off the machine) increasing preload should help this I'm thinking, I just don't want to pick up anymore RPM or increase belt temps if I do it what are some of your thoughts on this?
Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — mpi 190 straight pipe Thread Starter — madsledder Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 2 Last Post — 02-23-2017 02:07 PM
Thread — Extended warranty questions on MPI 190 hp Viper MTX Thread Starter — RMKing1 Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 2 Last Post — 05-01-2016 08:21 AM
Thread — Brand New Viper MPI 190 hp Turbo Kit Thread Starter — THE OUTLAW Forum — Turbos/Superchargers (Swapmeet) Replies — 0 Last Post — 11-20-2015 12:05 PM
Thread — Outlaw Motor Sports Viper MTX with MPI 190 Turbo Thread Starter — THE OUTLAW Forum — Vipers! Replies — 0 Last Post — 04-05-2014 08:41 AM
Thread — What team secondary helix and spring setup for turbo? Thread Starter — sledfvr Forum — Yamaha Replies — 4 Last Post — 01-16-2009 08:25 AM
no new posts
