Upgrade to Premium
Ski-Doo: ZX Sleds 99-2005, all models in the ZX chassis
Reply
  #1
Old 02-19-2017, 07:04 AM
Rick E Rick E is offline
Currently: Not set.
Basic Member
Rick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond repute
Default ZX Chassis Engine alignment question
I just installed a fresh engine in a 2001 Skidoo Summit 600. I believe that I have it fairly well aligned. I favored engine torque by setting the PTO side slightly forward.
Apparently there is an alignment tool for this, but I do not own this tool.
Are there any alternate "out-side-of-the-box" methods that you guys can suggest to me....... I.E., measurements, straight edge, off-set dimensions, etc?
Thank you in advance,
Rick E.
Rate this post: Yes | No
  #2
Old 02-21-2017, 05:35 AM
Currently: Not set.
Basic Member
Default
Anyone???? Any suggestions???
Rick
  #3
Old 02-21-2017, 07:09 AM
sledr4life's Avatar
sledr4life sledr4life is offline
Currently: Not set.
sledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond repute
Default
There are dimensions in the manual for the center to center distance and the offset. dont recall exactly what they are.
once those set, you could use a straight edge to make sure they are parallel.
always worked in the past.
you could also run the sled without the belt guard and watch the belt move move through the clutches. it will look crooked it they are not aligned correctly. make sure you have safety glasses on if you do this.
  #4
Old 02-22-2017, 10:47 AM
Currently: Not set.
Basic Member
Default
Quote:
Thanks.
Would you be able to point me to an on-line manual that would explain the process?
It is my understanding that we want to favor a slight PTO side FWD angle as to accommodate engine torque pull.
Is this correct?
What I find interesting is that with the primary clutch, as RPM increase, the outer shiv moves toward the right side of the chassis.
Whereas with the secondary clutch, the inner shiv moves in the oposite direction as RPM increase.
I'm sure that there is good reason for this.
Meanwhile, if any of you can point me to an on-line manual for this machine, I would sure appreciate it!
Thank you,
Rick E.
  #5
Old 02-23-2017, 11:11 AM
Currently: Not set.
Basic Member
Default
I found a few YouTube videos, but they do not go into any detail regarding center-to-center dimensions, nor favoring the PTO side being slightly foward as to accommodate engine side-load torque.
I would sure appreciate any further suggestions from you guys who have followed the OEM procedure.
Rick E.
  #6
Old 02-24-2017, 08:28 AM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
There should be X-Y-Z alignment specs in the Doo shop manual for your sled. They are measurements taken off a 3/8" diameter straight bar placed between the secondary sheaves and extend past the primary sheaves.
A google search should find you the specs which typically also have a image of where to take the measurements. Make sure it is for the correct chassis, the specs change for different sleds.
  #7
Old 02-26-2017, 11:02 AM
BBP BBP is offline
Currently: Not set.
Basic Member
BBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond repute
Default
Do yourself a favor & get your hands on the factory alignment bar. It makes it so easy. Post your location, maybe someone close by has one.
  #8
Old 03-01-2017, 07:57 AM
Currently: Not set.
Basic Member
Default
Good call on posting my location.
I am just east of Portland Oregon in Gresham.
I did end up finding several illustrations that may help.
It shows using a straight bar .375" X 19"
For the DSA/ZX platform it shows a center-to-center dimension of 10 - 9/64"
Does that sound correct?
Rick E.
  #9
Old 03-01-2017, 09:57 AM
BBP BBP is offline
Currently: Not set.
Basic Member
Default
Don't know, I have the factory bar. No measuring, just drop it into your clutches, shift the engine around & tighten it down.
  #10
Old 03-04-2017, 05:33 AM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Engine alignment and motor mounts Thread Starter — heynagel Forum — Arctic Cat: M Series Replies — 6 Last Post — 09-22-2015 09:11 PM
Thread — TRA Alignment question? Thread Starter — badapple Forum — Ski-Doo: XP Sleds Replies — 7 Last Post — 12-13-2011 12:07 AM
Thread — engine alignment Thread Starter — Chris the sled guy Forum — Polaris: 900 Replies — 7 Last Post — 02-28-2011 03:43 PM
Thread — Engine Mounting Alignment Thread Starter — E-Zmoke 4:20 Forum — Polaris: EDGE Replies — 22 Last Post — 11-28-2010 02:05 AM
Thread — Clutch alignment question Thread Starter — hyperduc Forum — Arctic Cat: M Series Replies — 15 Last Post — 11-15-2010 07:23 AM
no new posts
