Upgrade to Premium
Arctic Cat: 1M 2001-2005, all models in the Mountain Cat / 1M chassis
Reply
  #1
Old 02-09-2017, 03:03 PM
BigRedRider BigRedRider is offline
Currently: Not set.
Basic Member
BigRedRider is an unknown quantity at this point
Default King cat backfire
I have an 05 king cat 900 EFI, when i start it up cold it idles for a bit then backfires once and continues to idle fine. I have checked ground wires and connections. I was told a backfire can crack or break the reeds. Anyone know what could be causing this? Engine is stock, power valve deletes, v force reeds, a can and boondocker box.
Rate this post: Yes | No
  #2
Old 02-09-2017, 03:42 PM
IDspud's Avatar
IDspud IDspud is online now
Currently: Out to Lunch
IDspud has a reputation beyond reputeIDspud has a reputation beyond reputeIDspud has a reputation beyond reputeIDspud has a reputation beyond reputeIDspud has a reputation beyond reputeIDspud has a reputation beyond reputeIDspud has a reputation beyond reputeIDspud has a reputation beyond reputeIDspud has a reputation beyond reputeIDspud has a reputation beyond reputeIDspud has a reputation beyond repute
Default
Water in gas
  #3
Old 02-09-2017, 08:56 PM
Currently: Not set.
Basic Member
Default
I don't think so, it's done it every ride so far this season, and I fuel up before every ride usually around 10 gallons. It's got non ethanol fuel in it right now too.
  #4
Old 02-09-2017, 09:34 PM
IDspud's Avatar
Default
Condensation collects as it cools and warms each day inside the tank, adding water. If you don't proactively remove it with heet or similar product it adds up and backfiring is the result.
  #5
Old 02-09-2017, 11:33 PM
Currently: Not set.
Basic Member
Default
Ok, never had it backfire last season.... I do add startron every other ride.
  #6
Old 02-10-2017, 06:15 PM
Currently: Not set.
Basic Member
Default
Anything else I should check? Could it be a tuning issue? Sensor, coil, ect, any other ideas?
  #7
Old 02-12-2017, 04:14 PM
Readymedic's Avatar
Readymedic Readymedic is offline
Currently: How is 18/19 lookn'??
Readymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond repute
Default
Try a new set of plugs. I have had brand new plugs that are dead. I have also had plugs that have decent spark outside of the cylinder, but when installed under compression they don't fire and puke, fart and flood and puke out gas from the Y pipe and eventually the pipe.
Check your plug wires too. Those go bad on the older cats. Can even turn off the cap and cut 1/4 inch off so you get nice new wire and turn them back on tight but centered.
FYI.
The Following User Says Thank You to Readymedic For This Useful Post:
Idcatman3 (02-15-2017)
  #8
Old 02-15-2017, 08:43 AM
Currently: Not set.
Basic Member
Default
Turned out to be a bad spark plug boot wouldn't stay on tight.
The Following User Says Thank You to BigRedRider For This Useful Post:
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — BOSS seat fits Arctic Cat King Cat/1M, Mnt. Cat, and others $240 Thread Starter — FUchiZad Forum — Seats (Swapmeet) Replies — 0 Last Post — 10-28-2014 01:15 AM
Thread — ARCTIC CAT STATOR, MAGNETO, FLYWHEEL TIMING SENSOR: ZR ZL Mountain Cat, King Cat Thread Starter — 98woody Forum — Engine/Engine Parts (Swapmeet) Replies — 4 Last Post — 12-28-2012 04:55 AM
Thread — ARCTIC CAT IGNITION COIL ZR ZL KING CAT POWFER SPECIAL MOUNTAIN CAT FIRECAT Thread Starter — 98woody Forum — Engine/Engine Parts (Swapmeet) Replies — 2 Last Post — 12-21-2012 05:01 AM
Thread — mountain cat 600 bogging/backfire Thread Starter — powerstrokeguy Forum — Arctic Cat: 1M Replies — 7 Last Post — 02-06-2009 08:29 AM
Thread — 2004 King Cat Mod--Priced to Sell! (Misc king cat/1M parts for sale also) Thread Starter — Kingt8r Forum — Arctic Cat (Swapmeet) Replies — 7 Last Post — 03-23-2008 05:58 PM
no new posts
