Upgrade to Premium
Ski-Doo: REV Sleds 2004.5-200, all models in the REV chassis
Reply
  #1
Old 01-29-2017, 10:41 AM
rotax3006 rotax3006 is offline
Currently: Not set.
Basic Member
rotax3006 rotax3006 rotax3006 rotax3006 rotax3006 rotax3006 rotax3006 rotax3006 rotax3006 rotax3006 rotax3006
Default High fuel consumption
I have an 04 800 rev with a 159 that seems to be using way too much fuel. Out of gas at 41 miles. Riding was pretty easy not much powder just kind of an easy day. Seems like I should get more than that. Tank seemed full but it wasn't empty when I filled up so can't be sure. (possible air bubble). Motor is rebuilt a few rides ago, sled sat for all of last winter cleaned carbs seems to be running ok. Might have been a little rich but didn't foul any plugs. Thinking the dpm might need replaced/cleaned. Any suggestions are appreciated. Thanks Bill
Rate this post: Yes | No
  #2
Old 01-29-2017, 06:01 PM
lancelarue lancelarue is offline
Currently: waiting for snow!!
lancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond repute
Default MPG
DPM
__________________
Old faithful :06' Summit X W/163" flex,2 wheels in rear, big drop & roll. 860R, 05' electronics, 46 mm Lectrons, custom airbox, lots of air, SLP single, Paragon, Mtn Tamer rear w/ floats all the away around,extra cooling tubes in tunnel, premix, 5 gal race tank, >
Trail sled: 07' 151" stock except 860 & paragon, other stuff
The Following User Says Thank You to lancelarue For This Useful Post:
rotax3006 (01-29-2017)
  #3
Old 01-29-2017, 07:10 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Alpha Hawk!
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
Could be a DPM hose came off?
Mine did that, out of gas at 35 miles.
GS6
The Following User Says Thank You to summ8rmk For This Useful Post:
rotax3006 (01-30-2017)
  #4
Old 01-29-2017, 11:29 PM
turboless terry's Avatar
turboless terry turboless terry is online now
Currently: Not set.
turboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond repute
Default
Bet there was still 3 gallons in your tank when you filled it up.
The Following User Says Thank You to turboless terry For This Useful Post:
  #5
Old 01-30-2017, 09:16 AM
Currently: Not set.
Basic Member
Default
Quote:
Definitely out of gas, quit going downhill to the truck. put 3 gallons in it and if fired right up.
  #6
Old 01-30-2017, 09:19 AM
Currently: Not set.
Basic Member
Default
Can you clean and reassemble the DPM or do I need to just get a new one. I know that I can test the solenoid with a 9v. On a side note the tach quit working on the way in, would that have any effect on the operation of the DPM? The gauges have acted kind of strange for a while but they finally quit on this ride.
  #7
Old 01-30-2017, 04:39 PM
eddy's Avatar
eddy eddy is offline
Currently: Dirt Bike Season!
eddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond repute
Default Economy
Old gas uses up way faster than fresh gas. Check DPM hoses and check DPM solenoid operation per the factory manual. Carb inlet valves could be tired. Can of Sea Foam would not hurt.
  #8
Old 01-30-2017, 08:07 PM
Currently: Not set.
Default
All the revs would run out of gas going downhill. I would just drag them around, so they were facing uphill, and fire them up. Then drag them sideways and go. They always had 2 or 3 gallons that you couldn't get out of them
  #9
Old 02-06-2017, 09:31 AM
Currently: Not set.
Basic Member
Default
Pulled dpm off and checked it, appears to be clean and working properly. Will check the solenoid today as I couldn't find a 9v battery. Pulled the reed valves out, they look to be in good condition. No cracks or chips in them. I did notice that the airbox sensor was unplugged (I might have forgot to plug it in last time I had the carbs out). Im guessing that is probably the reason the DPM was not working correctly. What do you guys think? Thanks for all the input guys.
  #10
Old 02-06-2017, 10:08 AM
Calvin42's Avatar
Calvin42 Calvin42 is offline
Currently: Liv'n the Dream everyday
Calvin42 has a reputation beyond reputeCalvin42 has a reputation beyond reputeCalvin42 has a reputation beyond reputeCalvin42 has a reputation beyond reputeCalvin42 has a reputation beyond reputeCalvin42 has a reputation beyond reputeCalvin42 has a reputation beyond reputeCalvin42 has a reputation beyond reputeCalvin42 has a reputation beyond reputeCalvin42 has a reputation beyond reputeCalvin42 has a reputation beyond repute
The Following User Says Thank You to Calvin42 For This Useful Post:
rotax3006 (02-06-2017)
  #11
Old 02-06-2017, 10:30 AM
BBP BBP is offline
Currently: Not set.
Basic Member
BBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond repute
Click Here to Register
The Following User Says Thank You to BBP For This Useful Post:
  #12
Old 02-06-2017, 10:32 AM
BBP BBP is offline
Currently: Not set.
Basic Member
  #13
Old 02-06-2017, 03:31 PM
Currently: Not set.
Basic Member
  #14
Old 02-06-2017, 03:37 PM
Currently: Not set.
Basic Member
  #15
Old 02-19-2017, 04:51 PM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — fuel consumption Thread Starter — revriderx Forum — Ski-Doo: XP Sleds Replies — 14 Last Post — 03-10-2012 10:01 PM
Thread — 05 RMK 900 high oil consumption. Thread Starter — mike1971 Forum — Polaris: 900 Replies — 11 Last Post — 01-12-2011 08:37 AM
Thread — 06 m7 fuel consumption??? Thread Starter — 2500hd Forum — Arctic Cat: M Series Replies — 14 Last Post — 01-31-2010 11:22 AM
Thread — M7 Fuel Consumption Thread Starter — WYsteph Forum — Arctic Cat: M Series Replies — 6 Last Post — 01-02-2010 02:12 PM
Thread — High oil consumption Thread Starter — tpollon2 Forum — Ski-Doo: XP Sleds Replies — 6 Last Post — 12-25-2009 12:00 PM
no new posts
