Upgrade to Premium
Yamaha: 2-stroke Includes all Yamaha 2-strokes, Viper, Mountain Max, etc
Reply
  #1
Old 10-25-2016, 08:35 AM
Ratpack3 Ratpack3 is offline
Currently: Not set.
Basic Member
Ratpack3 is an unknown quantity at this point
Default 2002 viper with Aaen pipes
Hoping someone has the set up for this. Aaen said they don't. I need clutching and jetting for 8000'-10000' +
1) 2002 viper
2) 151"X2" 8 tooth drivers
3) opticool head gasket
4) huge rear cooler
5) aaen tripple pipes
6) ATACC fuel system
7) 8dn-10 weights
Rate this post: Yes | No
  #2
Old 10-25-2016, 04:26 PM
lonerider1 lonerider1 is offline
Currently: Working to much
Basic Member
lonerider1 has a reputation beyond reputelonerider1 has a reputation beyond reputelonerider1 has a reputation beyond reputelonerider1 has a reputation beyond reputelonerider1 has a reputation beyond reputelonerider1 has a reputation beyond reputelonerider1 has a reputation beyond reputelonerider1 has a reputation beyond reputelonerider1 has a reputation beyond reputelonerider1 has a reputation beyond reputelonerider1 has a reputation beyond repute
Default
Shooting from the hip from when we had a couple. The 8dn's were the weight. don't recall the spring or rivets. The secondary, we would switch between the 47 degree with a silver or green spring and the apex mtn helix with the same springs. It is a split angle. It depended on snow conditions. Your jetting may be safe with the atacc. Send them a note, I'm sure they would be happy to help. I ride between the Tushars in Utah to the Big horns in Mt and everything in between. Currently pull the trigger at 10 k in Co.
The Following User Says Thank You to lonerider1 For This Useful Post:
Ratpack3 (10-26-2016)
  #3
Old 10-27-2016, 07:31 PM
4strokeperformance's Avatar
4strokeperformance 4strokeperformance is offline
Currently: Ready to go sleddin.
4strokeperformance has a reputation beyond repute4strokeperformance has a reputation beyond repute4strokeperformance has a reputation beyond repute4strokeperformance has a reputation beyond repute4strokeperformance has a reputation beyond repute4strokeperformance has a reputation beyond repute4strokeperformance has a reputation beyond repute4strokeperformance has a reputation beyond repute4strokeperformance has a reputation beyond repute4strokeperformance has a reputation beyond repute4strokeperformance has a reputation beyond repute
Default Viper
It's been a few years but I had a great running Viper and this is what I have written down.
142.5 Mains
Clip in #2
55 pilots
21/42 gearing W 8 tooth 151"
I ran a 911 kit w 44 grams and stock weights.
Secondary was Hi tech E/R kit so can't help ya much there.
I also had the 3 filters in my airbox for more air.
To make this sled run you have to richen up the carbs by removing the vent tube from the airbox and let it hang down and vent to the underhood the way the SRX did. This will cause the carbs to go rich since the vacuum is removed from the float bowl.
So now when I tell you 142.5 mains, thats where I started. At 10k feet I ended up at 137.5s and it was a great running Viper.
Good luck.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — 2002-05 Yamaha 700 Viper SLP pipes Thread Starter — Snoghost Forum — Pipes/Cans (Swapmeet) Replies — 1 Last Post — 02-22-2014 11:12 AM
Thread — aaen ultra pipes Thread Starter — chevy509 Forum — Pipes/Cans (Swapmeet) Replies — 3 Last Post — 01-06-2009 10:42 PM
Thread — Aaen Performance Pipes Thread Starter — I.P.Yellow Forum — Ski-Doo Replies — 3 Last Post — 12-01-2008 06:36 PM
Thread — AAen pipes Thread Starter — chevy509 Forum — Pipes/Cans (Swapmeet) Replies — 3 Last Post — 07-14-2008 08:59 PM
Thread — Aaen Power pipes Thread Starter — 570MC Forum — Arctic Cat Replies — 1 Last Post — 03-03-2008 09:38 PM
no new posts
