Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 01-09-2016, 04:13 PM
Thunder101 Thunder101 is offline
Currently: making room in the garage :)
Thunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond repute
Default PC skid in M
I did this on my 11 M8 and the sled gets up on the snow much quicker and rides down the trail ten times better it also lifts the front of the sled more when boon docking making it easier to counter steer. It's a win win mod and thought I would share what I found.
PC skid arms are 2.5 inches closer to the rail tips so I kept the mounting points in the tunnel on the same "plane" and found 2 1/8 inches forward was the best spot for the front mount. Made new metal plates to go on the inside of the tunnel and after that you measure your center to center to remount you rear bracket. Yes it's some work but I think it's worth it.
Also you use your M arms and the PC rails.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to Thunder101 For This Useful Post:
Bills R.E. Repair (02-17-2016)
  #2
Old 01-09-2016, 06:13 PM
knifedge knifedge is offline
Currently: Not set.
knifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond repute
Default
M arms and PC rails???
--So basically you just changed out the rails, not the entire rear suspension, right?
  #3
Old 01-09-2016, 07:12 PM
Default
That's right you use the PC rails and move mounting points 2 1/8 inch forward.
I will post a pic tomorrow, I'm traveling right now
WyoBoy1000 (01-10-2016)
  #4
Old 01-10-2016, 03:39 AM
WyoBoy1000's Avatar
WyoBoy1000 WyoBoy1000 is offline
Currently: Working,
WyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond repute
Default
Always thought about it but after changing the pc I couldn't go back. I'm sure it's huge as it puts the skid under your feet and give way more rider control.
I've age pc rails would be better, smoother arc in the front
__________________
Shhhh, its a secret
Assume = when you as$,u,me you make an as$ out of u and me. Think, ask, get the facts and then go forward.
The Following User Says Thank You to WyoBoy1000 For This Useful Post:
Wrenchmaster (03-13-2018)
  #5
Old 01-10-2016, 01:17 PM
Default
Measure your center to center and your height off the floor of rear bumper and rear mounting hole.
I switched boards at the same time . Here is some pic's.
Click image for larger version
  #6
Old 01-10-2016, 01:19 PM
Default
The rear mount
  #7
Old 01-10-2016, 01:21 PM
Default
Dam phone will only do one pic at a time
  #8
Old 01-11-2016, 08:35 PM
WyoBoy1000's Avatar
Currently: Working,
Default
saw some rails and then a whole skid for sale on craigslist in CO
__________________
Shhhh, its a secret
  #9
Old 01-11-2016, 10:59 PM
Sledbrain2 Sledbrain2 is online now
Currently: Not set.
Basic Member
Sledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond repute
Default
I would like to see how you braced the front, also the rear is only 1 inch forward and the front is 2.2 forward?
Thanks for sharing
  #10
Old 01-12-2016, 12:39 AM
WyoBoy1000's Avatar
Currently: Working,
  #11
Old 01-21-2016, 07:30 AM
Click Here to Register
The Following 2 Users Say Thank You to Thunder101 For This Useful Post:
Bills R.E. Repair (02-17-2016), fordpickupman (01-10-2017)
  #12
Old 01-21-2016, 08:55 AM
The Following 3 Users Say Thank You to Thunder101 For This Useful Post:
Bills R.E. Repair (02-17-2016), fordpickupman (01-10-2017), Wrenchmaster (03-13-2018)
  #13
Old 01-22-2016, 06:22 AM
WyoBoy1000's Avatar
Currently: Working,
clutch (01-22-2016)
  #14
Old 02-13-2016, 12:20 PM
chevyman71 chevyman71 is offline
Currently: Not set.
chevyman71 is an unknown quantity at this point
  #15
Old 02-14-2016, 07:34 AM
  #16
Old 02-15-2016, 09:07 AM
boondocker97 boondocker97 is online now
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
The Following User Says Thank You to boondocker97 For This Useful Post:
  #17
Old 01-14-2018, 07:35 PM
  #18
Old 01-15-2018, 10:27 AM
Ddub's Avatar
Ddub Ddub is offline
Currently: Not set.
Ddub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond repute
The Following User Says Thank You to Ddub For This Useful Post:
Wrenchmaster (12-21-2018)
  #19
Old 01-15-2018, 02:37 PM
  #20
Old 01-15-2018, 06:14 PM
Ddub's Avatar
Currently: Not set.
  #21
Old 03-13-2018, 08:49 AM
Wrenchmaster's Avatar
Wrenchmaster Wrenchmaster is online now
Currently: working when I should be riding
Wrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond repute
  #22
Old 03-13-2018, 09:00 AM
  #23
Old 03-13-2018, 01:40 PM
  #24
Old 03-15-2018, 08:08 AM
Wrenchmaster (03-15-2018)
  #25
Old 03-15-2018, 12:11 PM
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2007 800 Skidoo 151" skid--low miles/Polaris 136 skid Thread Starter — Snoghost Forum — Suspension/Shocks (Swapmeet) Replies — 0 Last Post — 01-16-2014 08:45 PM
Thread — 2013 Proclimb Skid shocks in an M Series skid (09 M1000) Thread Starter — fishtank Forum — Arctic Cat: M Series Replies — 3 Last Post — 12-29-2013 01:48 AM
Thread — TIMBERSLED skid w/ fox floats... OR ...stock Float skid w/ EXIT shocks? Thread Starter — Bocephus Forum — Arctic Cat: M Series Replies — 8 Last Post — 09-08-2012 01:20 PM
Thread — Suspension rebuild and affordable 08-09 skid update to 2010 skid Thread Starter — Seeyacop Forum — Ski-Doo: XP Sleds Replies — 25 Last Post — 12-23-2010 04:16 PM
Thread — A stock 153" skid for a M7 or parts for rear skid Thread Starter — blackt Forum — WTB (Swapmeet) Replies — 4 Last Post — 12-17-2007 03:22 PM
no new posts
