Upgrade to Premium
Photography & Video All things Camera & Video
Reply
  #1
Old 01-10-2015, 07:39 PM
akbackcountry89 akbackcountry89 is offline
Currently: waiting for snow in alaska, who would have guessed that
Basic Member
akbackcountry89 is an unknown quantity at this point
Default go pro mount
i know there are PLENTY of people with go pro's out there. i recently put a helmet side mount on my helmet. put it on in the hotel room and it sat there all night and than in the parking lot the next day when i was getting my riding gear on...it just fell off! thankfully it wasnt while i was riding so i didnt loose the camera but is there something i need to do to make sure the mount sticky pad cures properly????
thanks!!
Rate this post: Yes | No
  #2
Old 01-10-2015, 11:38 PM
Clutched Films's Avatar
Clutched Films Clutched Films is offline
Currently: Not set.
Clutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond reputeClutched Films has a reputation beyond repute
Default GoPro mount
Make sure the surface is cleaned not just wiped off. Once you stick the mount on find a way to put pressure on it overnight. And sometimes they just fall off no matter how perfect your prep was. We tie string to our backpacks and the other end to our GoPro's.
  #3
Old 01-11-2015, 09:16 AM
TheHardWay's Avatar
TheHardWay TheHardWay is offline
Currently: Kill Mode
TheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond repute
Default
Prep the surface with some isopropyl alcohol, and then give it enough time to evaporate. I haven't had any issues with my mount coming unstuck. In fact, I hit a low hanging tree branch with my helmet mounted GoPro, and it snapped the plastic rather than causing the glue to come unstuck.
As mentioned, it's a good idea to use some sort of tether, which I now do. I had to go back with a metal detector and was fortunate enough to find my camera.
  #4
Old 01-11-2015, 12:35 PM
Basic Member
Default
good idea on the tether, went and bought the new fancy one and i would kick my self if i got back to the truck and there was no more camera....
it was a brand new helmet so all i did was wipe it off, but this time i will make sure to get some alohol on it as well.
thanks guys!
  #5
Old 01-12-2015, 09:41 AM
2Huskies's Avatar
2Huskies 2Huskies is online now
Currently: not being CBP any longer
2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute
Garage
Default
1) Make sure that you are applying the sticky in room temperature, that insures that the sticky is as sticky as possible
2) Just like the guys said clean it as good as humanly possible and insure it dries completely
3) When applying it dont be afraid to work the mount into the helmet to insure a tight seal.
4) Always tether the camera to the helmet. 10 dollar tether to save a 300-600 set up.
  #6
Old 01-15-2015, 02:59 PM
teal_210 teal_210 is offline
Currently: Not set.
teal_210 has a reputation beyond reputeteal_210 has a reputation beyond reputeteal_210 has a reputation beyond reputeteal_210 has a reputation beyond reputeteal_210 has a reputation beyond reputeteal_210 has a reputation beyond reputeteal_210 has a reputation beyond reputeteal_210 has a reputation beyond reputeteal_210 has a reputation beyond reputeteal_210 has a reputation beyond reputeteal_210 has a reputation beyond repute
Default
I heated mine up a little with a lighter. I've pulled on it pretty hard - it isn't going anywhere!
The Following User Says Thank You to teal_210 For This Useful Post:
2Huskies (01-18-2015)
  #7
Old 02-12-2015, 09:51 PM
Powderfreak56 Powderfreak56 is offline
Currently: Powderfreak56
Basic Member
Powderfreak56 has a reputation beyond reputePowderfreak56 has a reputation beyond reputePowderfreak56 has a reputation beyond reputePowderfreak56 has a reputation beyond reputePowderfreak56 has a reputation beyond reputePowderfreak56 has a reputation beyond reputePowderfreak56 has a reputation beyond reputePowderfreak56 has a reputation beyond reputePowderfreak56 has a reputation beyond reputePowderfreak56 has a reputation beyond reputePowderfreak56 has a reputation beyond repute
Default
I know this might seem obvious, but make sure you are not trying to stick a flat GoPro clip mount on a curved area. If you can rock that mount on your helmet, there isn't enough area that will be sticking to the helmet! I have never had a problem with them coming off. I had to take a mount off one of my helmets using a butter knife and it took me about ten minutes. That baby was on there.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 12V power cord, RAM Mount and windshield mount for Garmin 60 Thread Starter — snosub Forum — Communications Replies — 1 Last Post — 12-24-2012 10:36 PM
Thread — front mount or rear mount turbo Thread Starter — tuning forks Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 1 Last Post — 12-26-2010 05:54 PM
Thread — Can i move my rear mount 2 a front mount Thread Starter — night ryder Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 31 Last Post — 02-26-2010 07:58 PM
Thread — WTB or trade MCX RX1 rear mount for front mount Thread Starter — MRFUSION Forum — Turbos/Superchargers (Swapmeet) Replies — 0 Last Post — 01-10-2010 01:25 PM
Thread — Has anyone regretted going from rear mount to front mount? Thread Starter — sledfvr Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 18 Last Post — 09-28-2009 09:15 AM
